Question about GE Profile JTP18 Electric Single Oven
Burner light stays on - GE Profile JTP18 Electric Single Oven
G.e oven model # jbp3wb4ww burner light stays on when burners are off
Posted on May 05, 2010
Red light on stove stays on even when the burner is off
One of the switches has a short causing the light to stay on. Replacing the switch is the only way to correct the condition.
Sep 10, 2013 | Stoves Ovens
Why won't burners stay on
Alguien puede ayudarme con el diagrama electrico del horno imperial
gracias
Jun 20, 2013 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Flame does not always stay on after ignition, sometimes it does and when it doesnt you open and close the door for re- light ?
Opening and closing the door will reset the ignition sequence, do not do this repeatedly as you could cause a build-up of unburned gas in your heat exchanger and damage it. Instead verify that your ignitor is glowing, then see if the burner lights and make sure the flame carries all the way down to the bottom of the burner. If the flame stalls halfway or doesn't make it all the way to the bottom in 4 seconds after 3 attempts you will experience an ignition lockout, a safety feature built into your ignition module. If this is the case your burner needs to be cleaned and serviced, have a professional do it.
If the flame is reaching the bottom of the burner but still going out after about 4 seconds then you have a dirty/broken flame sensor. You can attempt to clean your flame sensor by removing the screw that holds it into the burner. With it removed it will look like a metal rod going through some ceramic, clean the metal rod part with a wire brush or emory cloth (fine sandpaper). Replace the flame rod and try again and see if the burner stays on this time. If it still goes out your burner needs to be serviced by a licensed technician.
Feb 11, 2011 | Baxter BXA2G Stainless Steel Gas Single...
My indicator lilght stays on even when the burner is off.
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Dec 13, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric stove with glass/cermanic top. Element on light indictor light stays on all the time even though no burners have been turned on for 5 hours. None of the burners are hot when you run your...
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
Nov 08, 2009 | Kenmore Ovens
Pilot light wont stay on
yes there should be a screw to turn near gas control knob at front there is one for each burner and the oven
Aug 26, 2009 | Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Element Light Stays oN
An element control switch has failed or a connection to the switch has fallen off.
Jun 09, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile JTP18 Electric Single Oven Logo
90 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
