Question about Car Audio & Video
How do I check the Transmission Fluid in a Suzuki Verona 2004? Where is it located?
  • 244 Answers
Sorry,
There is not one,the car has to be jacked up on a lift and remove a service plug to check the fluid and it also takes a special type of fluid known as ZF fluid.
HTH, Mike...
Posted on Dec 10, 2009
SOURCE:
Where is my transmission dip stick located at on my 2004 suzuki verona
Hi, If it is a manual Transmission you will not find one. On automatic transmission you will find it near the back of the engine near the firewall. sometimes marked with yellow or red paint on it.
Good luck.
Aug 03, 2011 | 2004 Suzuki Verona
I need to know how to fill the transmission fluid and check the levels in a 2004 suzuki verona as well as what fluid it needs. We had to buy a used transmission and the place we got it drained it so we...
well you have a dip stick like ware you put the oil in but do not put the transmission fluid in the oil dip stick ! it would be best to go and put a new filter in the transmission ! hope the transmission came with the dip stick ! you may have to get the one off the old one !
May 01, 2011 | 2004 Suzuki Verona
Just need to know what type to buy as far as trans fluid for 2004 Suzuki Verona?
ESSO LT71141 or TOTAL ATF H50235 Can only be purchased at your local Suzuki dealer as far as I know. But you for sure do want to use the correct fluid so get that fluid and nothing else.
Jun 12, 2010 | 2004 Suzuki Verona
I just purcahsed a 04 verona and can not locate the transmission dipstick?
check really good , but odds are it might be a sealed transmission meaning it can only be serviced by the dealer or removing the pan and using a special tool on a special underside service port.
May 15, 2010 | 2004 Suzuki Verona
Where do you check the transmission fluid
there is a little dipstick on the top of the trans. You have to look for it as it is not so obvious.
Apr 06, 2010 | 2004 Suzuki Verona
04 suzuki verona power steering fluid leaks.
What ever part is leaking,just have it replaced.
Jan 17, 2010 | 2004 Suzuki Verona
Where do i add transmission fluid or check the fluid level
Do you have the owners manual?
Trans fluid should be located near the back right side.A dipstick marked tran or transmission.You add in the hole where the dipstick goes.
Jan 10, 2010 | 2004 Suzuki Verona
I have a 2005 suzuki verona, where does the the transmisson fluid go
if its auto look for dipstick and fluid goes in there,under hood
Oct 28, 2009 | 2005 Suzuki Verona EX
Suzuki Verona 05- where do I refill the transmission fluid?
The 04 to 06 verona does not have a transmission dipstick, it is filled with a life time transmission fluid and thus does not need to be filled. If you have leaks and are concerned about the level there is a fill plug. BEWARE these transmissions do no use off the shelf ATF, Check with suzuki for the correct fluid and be sure to bring your checkbook
Jul 29, 2009 | 2004 Suzuki Verona
2004 Suzuki Verona
There is not a fuse for the check engine light.
Mar 14, 2009 | 2004 Suzuki Verona
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
