Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
Can you lengthen the beater by loosing a screw?
  • 235 Answers
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 11, 2009
  • Deborah Linzy
    Deborah Linzy Mar 24, 2014
    I did this but the beater still keeps hitting the bowl and making scratches on the bowl. What else can I do? Please email me at snowybear1957@gmail.com Thanks!
I have a kitchenaid K5SS. The beater keeps hitting the bowl even after adjustment screws was adjusted. What else can I do to fix problem
Check the four large screws at the back of the motor housing. They screw up thru the pedestal into the gear/motor housing. If they are loose that can allow the motor to tilt forwards. Check also the ones under the pedestal base, I have never seen those ones loose though and they would not cause your problem.
Mar 24, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Beater on Kitchen Aid stand mixer doesn't touch bottom of bowl
Why would you raise the beater if you want it to reach the bottom of the bowl? You need to lower the beater. Turn the screw in until it just touches with empty bowl on high speed then turn it counter clockwise a 1/4 turn so it will just clear.
Mar 16, 2014 | KitchenAid KSM150PS Artisan Series Stand...
I removed the beater to bowl screw. how do i fix it?
Hi Mary, There is no such thing as a beater to bowl screw. If you screw the beater to the bowl then it cannot turn without also turning the bowl. Here's a link to an exploded view
https://www.manualslib.com/manual/413887/Kitchenaid-Kt2651xww.html
Jan 16, 2018 | KitchenAid Kt2651xww Epicurean 6-Quart...
Just replaced planetary and gears, flat beater still heating bowl. is planetary to be loose or fit tight against mixer head?
The beater cannot "heat" the bowl, so I am going to assume that is a typing error, and you meant hitting.
If the beater hits the bowl it is usually caused by the adjusting screw at rear of the column being improperly set. To correct this you need to turn the adjusting screw slightly to right, or left to adjust clearance. Clearance should be 1/16", about the thickness of a dime.
If this does not fix the problem, and the beater still rubs the bottom of the bowl, it can be corrected by tapping the yoke arm with a mallet, there should be 1/16" clearance between bottom of bowl and end of the beater.
You can determine the 1/16" by dropping a dime in the bowl, the flat beater should just "touch" the coin as the beater rotates.
If you have questions feel free to call us @ the Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid KP2671 Professional 6 Series...
The mixing section has a gap in between
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid Food Mixers
Beater hits bowl beater height adjustment screw does not fix problem
Is this a new beater that you just bought? Or is it the same beater you have had? When you adjust the screw, which way are you turning the screw, how much is it hitting the bowl?
If the beater is too close to the bowl the adjustment screw should be turned in. If the threads on the screw are loose the screw needs to be replaced.
Page 17 and 21 both show how to adjust the head of the mixer so the beater his the bowl correctly. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Please let me know if you have any questions.
Thank you,
Colleen
Customer Service
MendingShed.com
customerservice@mendingshed.com
800-339-9297
Apr 14, 2013 | KitchenAid Artisan Series Tilt-Head Stand...
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Top wobbles and beaters scrape bottom of mixing bowl when in use
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 08, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Bowl too low
Hi, JAKELEGJEETE, You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 11, 2009 | Food Mixers
What screw do i turn on the standkitchenaid to lower the beaters?
Hi. You can adjust the clearance by turning the adjustment screw counterclockwise. This screw will only turn 90 degrees either way so dont try to force it any further than that. This adjustment dosen't lower the beater, it raises the bowl a bit.
With the bowl-lift in the low position, you'll see a screw on the column of the mixer facing toward the front. This is the adjustment screw. Use the flat beater to check the clearance.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 01, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
517 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
