Question about Westinghouse SK-19H210S Television
Repalaced bad capaitor(bulge on top) Now powers up. snowy with sound and picture goes blank. With nothing on screen. Tried to use remote but nothing shows up on screen. Note the snow is from not being hooked up. When you power up about 1 inch on both sides of the screen. then screen goes blank. Power still on and hear snow sound from speakers.
  • 11,361 Answers
When the filter caps went bad, the power supply output will be AC and feeding the circuits which can damaged the parts on the board. Check to see if you have the 12 or 18v feeding the back light invereter board. There are surface mounted fuses on the inverter board also. Send me good pictures of the whole back where all the boards are and close up picture of the inverter board, may be I walk you through. budmrtn@aol.com
Posted on Dec 10, 2009
Testimonial: "Thanks! May have found problem. Rookie mistake. "
  • Bud Martin
    Bud Martin Dec 10, 2009
    What was it?
  • Westinghouse Master
  • 8,457 Answers
Ur LCD inverter board it also dead,replaced it get picture back.
Posted on Dec 11, 2009
My samsung plasma tv powers on has sound and a picture, but is snowy, and coloring is slightly off. I have opened the tv to check for bulging caps and have found no obvious culprits. what next?
Snowy pics are not the symptom of bulging caps.
you must mention what type of source produces 'snowy' pics.
have you tried with other sources and ports ?
I recommend, you test out the following.
- DVD with Component connection
- HDR or STB with HDMI
- TV/Antenna
Aug 15, 2016 | Samsung Televison & Video
Screen Comes on and goes blank within 3 sec
Look for bad caps (bulging/leaking tops) in the power supply first, it may have taken out the fuse and transistors in the inverter circuits also.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 26, 2010 | Westinghouse L2046NV Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
Monitor with a blank screen
The monitor is about 2 years old, time to inspect the caps in the power supply first, look for caps with bulging top. The problem can also be in the inverter circuits, or bad lamps. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can help you more.
Mar 01, 2010 | ViewSonic Q191wb LCD Monitor
Hi i have a problem with my samsung monitor/hd tv, it goes blank in few sec's, you can see picture flashing light directly at screen. I changed Inverter board for a new one, still, nothing changed . One...
First, check to see if you do have 12vdc feeding the inverter bd. The problem can also be bad lamps (worst case). Capacitors look good? No bulging tops?
Jan 20, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
My x42 screen turns blue for a few seconds and then from the bottom of the display it quickly blanks. You can still hear the sound but the picture remains blank. I have tried to change sources but it...
The problem can be bad backlight inverter board or it is not getting the 24vdc from the power supply. Look inside to see if it has bad caps with bulging tops. Also check the power supply output voltages, you should have 5vdc, 12vdc, and 24vdc.
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Sceptre+X42GV-Naga&stock=all
Jan 05, 2010 | Sceptre X42GV-Naga 42 in. LCD Television
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Won't power on....
I think I have the same problem, If I don't use it for a couple of days, then try to turn it on, nothing. I turn it off, and on one more time, it works. WEIRD
Jan 10, 2007 | Polaroid FLM-2601 Television
Televison & Video Logo
564 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
