Question about Acer AC713 17" CRT Monitor
Help me sir to repair acer monitor model ac713 no display power button is turn green but no display? help me pls....
    Guru:
  • 1,481 Answers
Take it to a tech computer shot and get it fixed
Posted on Dec 10, 2009
SOURCE:
Power on problem
If when power is applied it fails to make any sign of activity upon pressing the power button, then the power supply has likely failed. In this case, it is far cheaper to just replace the monitor.
May 14, 2011 | Acer AC713 17" CRT Monitor
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
Contrast on my desktop is displaying as 100%
problem with front panel control switches. check if button struck ed. need to replace the 3rd push button from the left ( beside MENU button)
Sep 07, 2010 | Acer AC713 17" CRT Monitor
Acer aspire d150 netbook problem,pls help me..
Suddenly stop means off?? Maybe cause by thermal pad at fan so thin. So you need to send it for change the thermal. Not so expensive
May 13, 2010 | Acer AC713 17" CRT Monitor
My acer AC713 monitor's brightness value gets reduced to zero.
Dear sir,
This is common problem arises mainly due to moisture,especially in rainy season,Monitor front panel control buttons remain pressed,due to deposition of ferric oxide and moisture in between monitor botton panel and circuit board.So you can dry this moisture by hanging a bulb of 60 watt nearer a monitor about 4-5 hrs,(too near may damage the internal heat sensitive parts.).It solves your problem.....and also you may clean the inner monitor button contacting circuit by means of PCB cleaner to wipe out ferric oxide deposition.
if you had any query regarding this issue leave a feedback we glad to assist you.
good luck.
Sep 10, 2009 | Acer AC713 17" CRT Monitor
Acer CRT moniter 17" Model: AC713 dost not display any thing.
Ok if you prese the menu button on the monitor does the monitors setting menu appear on screen
If it displays adjust the contrast and brightness until a picture appears
If that does not work place a fringe magnet on one of the corners of the monitor if there is now green tinge around it than there is no electrons being fired at the screen and you have missed something so test every component
Mar 14, 2009 | Acer AC713 17" CRT Monitor
ABOUT VGA DRIVERS
Check this on (driverguide.com).Or its regional site
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 11, 2008 | Acer AC713 17" CRT Monitor
ACER AC213
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards.
Mar 21, 2007 | Acer AC713 17" CRT Monitor
Acer AC713 17" CRT Monitor Logo
146 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
