Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Danby Dishwasher stuck in drain cycle after wrong soap use
I have a portable Danby Dishwasher DDW1805W. It worked great until someone accidentally put liquid dishwasher soap in it. It made lots of suds and overflowed, then it drained itself, but would not move beyond a drain cycle. I added fresh cold water and washed the inside several times so there are no more visible suds. The water pumps out every time, but the pump stays on even after the dishwasher is empty, regardless of where the dial is, or with moving the dial manually. It seems to be stuck in the "need to pump out" mode!
Any suggestions?
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Posted on Jan 10, 2010
My Danby dishwasher repairman told me that there is a reset button somewhere inside the dishwasher (unavailable to user, supposed to be reset by repairman) that is triggered by too much detergent/sudsing. Apparently it is also triggered by turning the dial to try to bypass the dry cycle. I did the latter, since I wanted to save electricity and air-dry the dishes. Reset button went off. Am trying to figure out how to reset it myself. Anyone know? It took the last repairman (free, since it was still under warranty) only 5 minutes to reset it.
Posted on Sep 09, 2010
Danby DDW1805W dishwasher won't drain
I had this problem and I had to take the shared drain pipe apart. I found a huge cement-like plug of coffee grounds mixed with flour from bread-making. I removed it all and now the machine drains freely.
Jun 13, 2014 | Danby DDW1805W Designer Series...
Dishwasher stays on drain cycle stuck..
hold reset button in for 15/20 seconds.adrian,,,,,,
Jul 13, 2010 | Danby DDW1805W Designer Series...
Danby Designer Dishwasher sprayer arm stopped working
is anything in the way of the arm? Sometimes you can't see an item sticking down too low ... interfering with the spinning.
Oct 05, 2009 | Danby DDW1805W Designer Series...
Has power but will not come on????
Have you checked the arm? If it is in the up position ... simply push it down. maybe something flipped the interior switch... check that also.
Sep 27, 2009 | Danby DDW1805W Designer Series...
Portable Dishwasher Faucet Adapter Comes Apart
I'm glad to hear that solved the problem. I hope the new adapter comes quickly.
Jun 02, 2009 | Danby DDW1805W Designer Series...
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
My portable danby is stuck on the Drain cycle
take bottom front panel off to expose bottom tray and you will probably find it full of water. disconnect from electricity and mop water out and machine should work. if fault reoccurs then you have a leak
Sep 25, 2008 | Danby DDW1805W Designer Series...
Danby countertop dishwasher
i would think the drain hose from the unit is leaking from the description you give.let me know
Dec 24, 2007 | Danby 22 in. DDW396 Free-standing...
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
1,507 people viewed this question
Top Danby Dishwashers Experts
Jose Pino
Carmen Mikulic
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
