Question about Cell Phones
I have CVFD-M31 Touchscreen Phone but it has muted the microphone so when the phone connects one can hear the other party but they can't hear anything from me. Any ideas how to unmute it?Thanks in advance
Ican hear the other party but they cannot hear me. Nokia 6350
Hello.
Diagnosis:
Your Nokia 6350 Inner Microphone is defective.
Causes:
The Phone was dropped or smashed.
The Phone got liquid damage.
Solution :
Replace the Microphone.
Not an easy task to do, doing this repair procedure with no Professional Tools, may cause further damage to your phone.
In this Case,i recommend you :
  • (if you still under warranty) to give it to your nearest "Genuine" Nokia Shop for reparation.
  • a trusted Phone repair shop, this repair won't cost you less than 12-15$.
Best Regards.
Oct 25, 2011 | Nokia 6350 Cell Phone
I can hear people, but they can't hear me - apparently my microphone isn't working (and no, it's not set to 'mute')
Check if the microphone is not muted. The mute button is at the top left of the keypad when a call is being received or made. If the mike is not muted, then try the following steps:
I. Switch on phone with SIM Card.
2. Select Menu.
3. Select Settings.
4. Select Call.
5. Select Hearing Aid.
6. Set Hearing Aid to OFF. And that should solve the problem. If this does not work then the microphone might be damaged and may need to be changed.
Jul 24, 2011 | LG CF360 Cell Phone
I cannot hear people when they call me but they can hear me. If I call out I can hear the other person but they cannot hear me
There are three possible problems that I can think of.
1) Probably the most obvious. Your microphone is broken. This could have happened if your phone took a tumble
2) The wire inside of the phone connected to the microphone is disconnected or ripped.
3) You have your in-call settings on Mute. Next time you make a phone call, see if it says "mute" anywhere on the screen.
I would bring the phone to your carrier's nearest store and have them look at it. If it's a problem that arrived without you being at fault, they should replace it for free.
Hope this helped!
Please rate my solution
- Frankie
May 06, 2011 | Motorola Mobility Defy Cell Phone
When making or recieving a call, i cannot hear the caller but they can hear me. the volume is up so i dont no what the problem is
Your phone is either muted on your end or the microphone has gone out on it. Next time you're in a call look in your call options and see if there is a mute option, or see if there is a microphone symbol with a line through it on your call screen. If there is a microphone symbol with a line through it click it to turn the mute off. If you don't have a mute option on your phone then chances are the microphone has gone bad.
May 03, 2011 | Samsung Solid B2100 Cell Phone
When calling,i can hear the person i called but they cant hear me
Hi..
Looks like problem is on your side. This is may due to a faulty microphone on your phone or Mic is set to be on mute.
1. Please check that nothing is clotted on Microphone. This is a small hole on bottom side of your phone.
2. Please check that other party can hear you when you're using a Hands-free / Bluetooth ear phones with mic on it. If they can hear you, when you use a hands-free, problem is with your phone's on-board microphone.
3. You can also check that, while on a call, your mic is not set on Mute. This can be done as on call, select Options , look for Mute / Unmute. If Unmute is present, select it unmute the mic.
4. You can use Mute button Provided on the top side of the phone. While on the call, press this button to Mute / Unmute the mic. If the mic is set to Mute mode, other party won't hear any sound from you.
Hope this will solve the issue.
Mar 13, 2011 | RIM BlackBerry Bold 9700 Smartphone
Samsung Link I can't hear my callers & they can't hear me
hello,
to find out if the phone is on mute, try to connect a earpiece to the phone and see what happens.
if it continues, then you flash the phone with the appropriate software.
it will come back to order.
take care
Jun 02, 2010 | Samsung T239 Cell Phone
My I bought a completely unlocked CVFD-M31 cell phone from China. and cant connect to the web i have t mobile
You need to obtain first the network settings for your phone from t-mobile. Just contact there customer service for this settings..
Mar 29, 2010 | Cell Phones
How do I make the microphone work? I can hear the other party, but they can't hear me
The biggest thing woul be check your sound settings on your comptuer and make sure its not muted. also if thier is a switch on the headphone make sure they arnt muted,
to check your comptuers volume settings, look for a speaker phone down by your start menu, or go to your control panel, look for anything that has to do with sound. open that open, and just make sure the mic isnt muted,
Nov 05, 2009 | Motorola Mobility S9 Headphones
I bought a completely unlocked CVFD-M31 cell phone from China. It is good, but.....I can not get it to work on the internet. I subscribe to Vodafone and 2 degrees and they are no help at all. It is to do...
I figured it out...
Step 1:
Click on the Globe symbol in menu.
Data Account
GPRS
Edit Account 1
APN: live.vodafone.com
Username and password: blank
Auth. Type: Normal
Step 2:
WAP
Settings
Edit Profile
SIM1
Select a profile
Edit profile
Rename: Vodafone
Homepage: http://google.com/m?hl=en
(note: Without the above, google defaults to Chinese)
Data Account: Account 1
Connection Type: WAP (Select WAP, OK takes you to another screen)
IP Address: 172.030.038.003
Security: Off
Save this then go all the way back to WAP homepage and it works!!.
Oct 30, 2009 | Cell Phones
Microphone has stopped working
Check the channel switch on the transmitter unit. Change to the opposite channel and retest. Check that the batteries are still good in transmitter AND receiver unit good luck
Jan 09, 2006 | Motorola Mobility MA550 Cordless Phone...
Cell Phones Logo
224 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
