Question about InFocus ScreenPlay 4805 Multimedia Projector
Projector only projects black and white images
  • thoroughb898 Dec 10, 2009
    The system was professional installed and uses a white, red, yellow and one additional cable. The original projector went bad and I replaced it with this one. The old projector had great color. Now all I get is black and white.
  • Mark R B May 11, 2010
    Are you using the "S" Video input?
  • 2,237 Answers
If the cables are fine, try resetting the settings to factory default. if still no good, you may need to replace the colorwheel. you could buy the part and do it yourself, or send it in to an infocus service center. either way, try www.avsolutionsny.com. they're really good.
Posted on Dec 10, 2009
I suspect that your one additional cable may be an "S" video cable. I've experienced bad cables or connections where the black and white portion of the video is being passed but the colour portion is not. I'd check that the existing cables are inserted all the way (maybe even wiggle them a bit) and if that doesn't work, try another cable. Off note, I'm nut sure of your source, but there are higher resolution connections than the Composite "Yellow" input.
This may be an opportunity for you to upgrade to a Component or HDMI input connection.
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
Was watching the projection and everything was fine. Then a loud pop/glass breaking sound was heard. Immediately, the projection could only be seen in black and white (no more color images). Help!
Souds like a Dlp projector and the wheel inside broke is what it souds like what happend, I would have this serviced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 13, 2009 | Sharp XV-Z2000 Multimedia Projector
Black and white specks from InFocus X1 projector
if you can get a menu when you press the menu button, reset the settings to factory default. if you don't get a menu, the color wheel or the dmd chip is bad. either way, you'll have to replace the entire optical engine. and unfortunately, infocus no longer has any more in stock.
Sep 06, 2009 | InFocus X1 Multimedia Projector
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
My projector only shows black and white images
probably you are facing with an NTSC signal and a PAL source or vica versa
try to check with a regular tv or with a different source
Jan 03, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
InFocus
Hi there
That is a definate Mainboard replacement.
Must warn you that it could turn out to be a expensive exercise
Feb 06, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projection horizontal lines and flickering
This is the problem I had with a couple of my projectors, one of them I just replaced the bulb and the other needed whole new brains (controller board)
Feb 01, 2008 | Dell 3200MP Multimedia Projector
Tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
Feb 02, 2007 | Sanyo PLC-XT16 Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
108 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
