Question about EnGenius EOC-3220 (EOC3220)
I made firmware 1.39 to SENAO ECO3220
HI
I HAVE A SENAO 3220 EXT, DOWNLOAD FIRMWARE 1.39.
NOW, NOT ACCES TO SENAO
YOU CAN HELP ME !!
  • Anonymous Apr 19, 2009
    i have senao EOC-3220,client can detect my wireless but they can"t connect.can you tell me what the problem is??
Hey maick, I have the same proble, but I fix it, try this: 192.168.1.254, for me work fine, after that I reload the new firmware. now is working fine. good luck, jose luis Ogawa
Posted on Mar 27, 2008
  • 3 Answers
Download.gblmedia.com
Posted on May 02, 2009
Http://www.gblmedia.com/forum/
Posted on Mar 21, 2008
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
Problem using 2nd hand AP senao EOC3220 EXT
You can use this unit either as an access point, to provide wireless access to a network you already have, or as a bridge, to access a remote wireless network someone else has.
Note that you own the EXT model, meaning that you have to attach your own antenna to the connector before it will function. There is no internal antenna on this model.
Configuration instructions are available at
EOC-3220 Series User Manual
Factory reset instructions are available at:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
May 14, 2009 | EnGenius EOC-3220 (EOC3220)
My senao eoc-3220 is showing SSID as 802.11g-SSID. But it does not acquire an IP automatically. I tried using defaults but that does not work either. Trying factory reset does not work because the "#"...
Hi
I had the same problem. This may be as simple as pressing the enter button on your computer keyboard after all the activity stops. This brought up the number sign for me after which everything else in the reset procedure worked fine.
Dec 22, 2008 | EnGenius EOC-3220 (EOC3220)
Senao USB wifi 802.11
I am afraid that I have had to make an assumption as to the precise modle that you have but the following link should be correct, it gives you the option to download drivers for the
Senau NUB362 (Ext)
http://www.senao.com/English/Default.aspx?TYPE=test.htm&PT=searchDownload1&sf1=D331&sf2=NUB-362(EXT)&sf3=&tv_TCAT_POS=0&CATNO0=D&IDX=3.2&CNT=1&CATNO1=D3
numerous drivers for different operating systems seem to be avaliable.
if I have chosen the worng type a pull down list is avaliable showing the differnt Senao product drivers avaliable.
Nov 14, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Site survey no signal
Site Survey is meaningful only in bridge mode, not access point mode. Assuming you are operating this unit in bridge mode, it could be possible that no signal is being detected because there are no access points nearby for it to detect. If you know that there are, in fact, working access points in the vicinity, then my first suspicion is that you have a faulty unit.
Jul 14, 2008 | EnGenius ECB-3220
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
Also
May 08, 2008 | EnGenius EOC-3220 (EOC3220)
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
1,341 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
