Question about Garden
I need a schematic for a 5.5HP Tecumseh. I had a small engine repair shop tell me they wanted 200 bucks to fix my govenor on my Craftsman Snow Blower. I decided to fix it myself but there were some parts that fell out when I removed the cover and now I'm not sure where they go now.
mailtoravi
  • 186 Answers
SOURCE: AC Jack repair
First of all...it is complex process to replace the Power Jack of any Notebook as it may cause the Notebook useless if the Power Jack is fixed incorrectly....
If you are interested, you can purchase the required Power Jack for your Notebook by selecting the appropriate part from the link below :
http://www.laptopjacks.com/product/Compaq-Laptop-DC-Power-Jacks.html
You can access the Service Manuals of your Notebook from the links below :
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
OR
http://h10032.www1.hp.com/ctg/Manual/c00636251.pdf
Hope this helps...
Posted on Aug 20, 2008
HW_Dude
  • 87 Answers
SOURCE: tecumseh 8hp HIGH REVING! snowblower
be careful, if the engine over revs it may just explode. These engines are very picky if over sped and easily blow up.
Your problem may be a broken throttle control rod, have look at that first. If the control rods are fine and in place it could be the fly wheel governor is worn out.
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: Snow Blower engine runs very rough
YES THE CARBURETOR CAN BE OVERHAULED
THE REPAIR KIT PART # IS 31840 , THE BOWL IS REMOVED BY REMOVING THE BRASS NUT ON THE BOTTOM WITH A 7/16" WRENCH.YOU MAY NEED TO REMOVE THE WELCH PLUGS FOR A GOOD CLEANING. NEW PLUGS COME WITH KIT. YOU CAN SOAK CARB. IN CLEANER SHOULD BE NO LONGER THAN 15 MINUTES. ALWAYS USE NEW GASKETS. ADJUSTMENTS TO BE DONE WHEN ENGINE IS WARMED UP.
Posted on Jan 26, 2009
SOURCE: Surging tecumseh engine on snow blower
Hi, You have gum or old gas in the main jet on the carb, turn your fuel off, stand the snowblower on the front blower housing with handles in the air, remove main jet from the bottom of the carb and clean. Jim
Posted on Feb 01, 2009
  • 42 Answers
SOURCE: tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
Posted on Mar 25, 2009
My 12 years old Craftsman snow blower suddenly died after hearing a bang. Start pull is stuck. Electric start runs, but doesn't seem to be engaged. Thank you for the help in advance!
I suspect the engine is locked. What is the oil level and condition. You can further investigate by removing the starter housing and try to rotate the flywheel. You can remove the cylinder head to inspect if the piston is moving. I suspect the engine will need to be replaced. The original engine is no longer manufactured by Tecumseh (out of business). You may want to replace the snow blower. This is of coarse a worst case senario
Feb 11, 2017 | Craftsman Garden
How do I rebuild a 7 hp Tecumseh motor
Don't bother. If you go to your local small motor' repair shop or the local dump/ waste recycle center you will find lots of old lawn mowers or in your case snow blowers that have been discarded for reasons other than the engines. The Tecumseh engine is usually the last thing still in very good shape and you can get it for a very low price. By mistake I left one out side all winter under snow and rain, it started first pull in the spring.
Nov 06, 2014 | Tools & Hardware - Others
Why is my v8 surging while under load
govenor not set correctly. weak fuel pump diaphram.
Jul 06, 2014 | Tecumseh Snowblower Snow Blower Starter...
The primer button on my snow blower won't force gas into the engine
The primer bulb may need replacing as they do crack with age and will not work. A small engine shop should fix you up .
Nov 29, 2013 | Garden
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Need new air filter for a tecumseh shredder chipper 10 hp
You can look up the air filter with the model number and order it over the internet from a website such as partstree.com, but there are others. Or, you can get the model number and go to your local small engine repair and parts shop. Mine had it on the shelf. If your chipper/shredder is like my 8 HP Craftsman with a Tecumseh engine, then as you are looking at the engine, look on the left side of the shroud or cover and way down low on the curved portion is a label with the model number on it.
I hope this is helpful for you.
Aug 22, 2011 | Tecumseh Heavy Machinery
I have a Yard Machine chipper shredder with a tecumseh motor with the 3 way feeding system ... I need the gas tank for this machine ... any idea where to find one?
If you have the same 8 HP Tecumseh engine that I do then if you look at the the engine, squat down so that you are looking at the recoil starter, then look for a label on the left side of the shroud (cover) down low and you should find the model number of the engine. Record that number and send it to me so I can check it. After I check it I will tell you what website to go to in order to order it or how to get the part number so your local small engine repair shop can order it for you. You can also just take the engine model number to the local small engine repair shop and tell them what you want to order and they should be able to get it for you.
If you go directly to the local shop, I hope you get it going soon.
Aug 05, 2011 | Yard Machines Electric Chipper/Shredder
I had to repair pull cord, in doing so I took the throttle linkage carborator linkages off to get to the pull rope housing. I need schematics to show all the throttle control springs wire hook up to get...
go to sears.com and look up the actual engine number. they have a section for lawn and garden and in there there is a link to their parts lookup and they are very detailed. but you will need a pulse tach to set the govenor back to where it was and if it spun the govenor open too far due to the govenor not being hooked up, it could have came apart inside the motor and you will need to take it to a shop. as far as setting the govenor once you get it all back together, you need to push the throtle wide open and turn the govenor shaft in the same direction then tighten it down. yeah its not hard if you have done it before but if you havent and cant understand what i just said, save your time, and engine and have a shop fix it. and i havent seen a motor in my 9+ years that you had to remove all of that to fix a recoil rope.
Feb 03, 2010 | Craftsman Rear Mount Tiller
I have a tecumseh 7 horse (Snow King) motor that has a blown head gasket. Model number is HSK 70. Where do I find a part number to order replacement gasket?
That does not sound like a complete Tecumseh model number.
You have several options... Your first and probably best option would be your local small engine repair shop. They may even have the parts in stock, if not in stock will likely have it in a few days. Or you can look online at places like outdoordistributors.
No matter where you get the part from you will need a complete model and spec and maybe a serial number ( off of the motor itself). Also be aware that since Tecumseh went out of business a few years ago that certain parts are becoming increasingly hard to find.
Jan 02, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
