Question about Reddy Heater-30-55,000 BTU Variable
My unit has no spark. What or how do I check if I have any power?
Unit will not fire up, I hit the reset makes a little nose then it stops
I have older unit
Posted on Dec 14, 2009
Why don't I get spark on my rd125 Yamaha? If I put the power cable straight to coil I get spark. But if I don't then I get nothing? Can someone help me out please
If putting 12v on the + contact, you get a spark, check the power feed. If on the - contact, replace the ignition unit.
Apr 10, 2018 | Power Motorcycles
Unit does not power up
try replacing the power cable. and you might want to make sure it didn't short circuit when it sparked.
Jun 30, 2008 | Audio Players & Recorders
2002 mitsubishi galant 1 and 4 spark plugs no spark ....i need help . . i change the coil and plugs already still no spark..
Look more closely at the 1 and 4 coil, also, check for trigger signal to these coils. I mostly suspect the trigger unit.
Dec 04, 2014 | 2002 Mitsubishi Galant
I do not have any spark at my spark plugs this after I replaced my voltage regulator
check ht cap ..check ht lead, check condition of cut out switch, check power coming from coils, check power coming from cdi unit,
Feb 16, 2013 | 1983 BMW R 100 RT
My 1990 hond accord will turn over but wont start can you please help
MAKE SURE SPARK PLUGS AND WIRES IN GOOD CONDITION, REPLACE DISTRIBUTOR CAP AND ROTOR,CHECK FOR SPARK AT SPARK PLUGS,IF YOU DONT SEE SPARK CHECK TO SEE IF POWER GOING TO COIL IF NOT CHECK IGNITION FUSE.IF FUSE OKAY AND POWER GOING TO IGNITION COIL,COIL FAULTY OR IGNITER UNIT FAULTY. CHECK FOR FUEL PRESSURE MAKE SURE FUEL FILTER BEEN CHANGED.FUEL PRESSURE SHOULD BE 40 PSI. IF YOU GETTING SPARK AND FUEL. YOUR IGNITION TIMING OFF OR VALVE TIMING OFF DUE TO A WORN TIMING BELT.
Nov 01, 2011 | 1990 Honda Accord
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Can not get heaters elec spark to spark upon turning on. Replaced module with no differance. i have verified power to unit to be 220v. heater has not been fired this year however it worked fine this time...
Hi David--
Assuming the spark unit is clean and properly gapped, and all connections are clean and tight, check the ground connection at the module. Turn the unit's power off, and look for a green wire coming from the module. This should land somewhere on the unit's body. Be sure this wire lands tightly and on a paint and rust free area of the body. Also, check that the spark unit itself is tightly grounded. This is often accomplished via the sparker's mounting assembly.
--Hope this helps, Joe
Oct 08, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Wont start
firstly check your fuel .
how old is the fuel in the tank ?
Have you left the bike in the rain and water might found its way in the tank .
check your spark plug which may be burned .
check if you have a spark .
check your HT cable to your spark plug
the HT may be dead too and may have burned out which is common .
if you have a spark at the plug , check if fuel flows to the cylinder .
try to start the bike without the spark plug in place and try to smell fuel .
if you cannot smell fuel while trying to start your bike you may have a problem at your carbi and it will need cleaning .
the last thing i hope its not ... the main ignition unit which regulate the power to the HT unit and if this unit has died you will have to replace it but may be costly
Sep 26, 2009 | Yamaha XT 600 E Motorcycles
No power to the spark plugs
Check first the wire connections to your ignition unit. Are they properly plugged? If all wires are good, try to measure the voltage from one of the wires to the ignition unit while the ignition key is in "on" position. If there's no voltage, have someone check your ECM. If there's a good voltage reading, try replacing your ignition unit with a good one.
Jul 10, 2009 | 1994 Suzuki Sidekick
Bosch13 gas tankless water heater no spark
Well if you don't have no spark,have you check to see if you got power?If you do have power ,the turn the water on to see if it will spark.If not the Check to see if the fuses are blown insde the panel.Most of them have fuses on the power coming in.If got all of that then you proablly wil have to replace the igniter board.
Mar 15, 2009 | Bosch & Tankless LP Hot Water Heater
Reddy Heater-30-55,000 BTU Variable Logo
102 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
