AM radio does not work - Audio Players & Recorders
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 152 Answers
Does it have a antenna ? you live in a moble home.
what type of a.m. radio ? car/port/home type with fm/ if the last type does the fm ok... did it ever work did you drop it? did you try a ear phone maybe the speaker is shot. did you put new batteries in it / plug it in / turn it on/ no batteries/ plug pulled out.... check all these options then write back.
Posted on Dec 11, 2009
Cd player work but no radio
Assuming the vehicles antenna is intact and in one piece, check the antenna connection behind the radio. If the antenna is connected behind the radio, there could possibly be a problem with the radio's tuner (internally). The only way to properly diagnose this problem is to place a radio that is known to work into the vehicle (simply to test) and check the radio reception. If the radio reception is improved and working, you know the problem lies within the radio itself.
If it still does not work, there is a problem with the antenna on the vehicle (disconnected, damaged, cut, etc.)
Mar 21, 2016 | Cars & Trucks
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
Lost power to my house, came back on outlet has power clock on radio works radio has no power. wall clock on same outlet works fine
There is a battery backuo in the radio. This is probably powering the clock. It looks like the radio power supply is either fried or the hardwired fuse is blown.
Take a look at the manual. If you take out the battery back up does the clock still work? GPX MP3 Player KC232S user manual
Apr 12, 2015 | Audio Players & Recorders
Why does My Bose Wave AWR1C2 radio only works on the alarm. Radio has no sound
My radio stopped working. I was able to take it into a Bose store and trade it in on a new radio. My old one was about ten years old and it did not have a CD player. I was able to trade it in on a new one with a CD player.
Jun 28, 2014 | Bose Wave Radio
97 GMC 1500 radio worked fine and recently stopped. Radio will only work when truck is turned off. Volume will not work either. All fuses are good and wiring to the radio is good after testing. Should I...
radio's do fail if the radio and nothing ells is wrong you can replace the radio. buttons stopping working on the radio is a good sign there is a problem with the radio and nothing ells is wrong with the wiring. it may have over heated some time ago and has been working on borrowed time from the other components in the radio. now working with the engine running is down to there is more volts running into the radio with the engine running . no engine running it will have a steady 12v around. but with engine running it would be around 14v or just under. would replace radio one from same year as yours or same radio code type. hope this helps you
Feb 16, 2014 | 1997 GMC Sierra
My motorola radius GP 300 suddenly stoped working, disconnected from programmed network, how can i connect back and sees it working back?
GP300 radios will operate either radio-to-radio or in conjunction with a repeater. If your radio no longer works through a repeater, you might check to see if it will work in talk-around mode (radio-to-radio). Check with your repeater service provider to see if the repeater is in working order. One other item which might occur with a repeater would be if your radio is no longer recognized by serial number by the repeater. This is also something the service provider could help you with.
Best regards.
Apr 21, 2013 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
Why won't FM radio work on the Motorola 6310 two-way radio?
It's a two way communications radio, not a broadcast radio, hence it won't receive FM/AM broadcast radio stations.
You should not confuse the two as they work on different radio bands, most FM broadcast radios are on the 86-108MHz bands, whereas two way radios operate on the following bands:
1-86MHz, 108-174MHz, 220-520MHz & 865-920MHz
I don't know which band your radio works on, but not broadcast bands I'm sure.
The only exception to this is the smaller hand helds, which may have FM broadcast programmed, but if this is the case with yours, This issue is out of the realm of two way radio queries, as Broadcast radio is not two way radio, but one way radio, and I'm not competent enough to answer Broadcast radio issues.
Cheers, Peter@FixYa Team
Nov 17, 2012 | Radio Communications
MILWAUKEE JOBSITE RADIO'S CLOCK DISPLAY WORKS BUT NO RADIO
if it work on battery and didnt work on 120 volt,the transformer is dead,i see a lot of radio with dead transformer.
if it dont work with battery and 120v,the control board have problem.
Oct 18, 2012 | Milwaukee Tool 49-24-0200 AM/FM Radio
Radio in 2009 ford focus does not work checked fuses and they are ok
Check to see if you get power and ground at the radio. If you get power and ground then the radio may be faulty. Also if you get the radio out see if there is a fuse on the back of it and check it if there is one
Jan 07, 2011 | 2009 Ford Focus
When radio is plugged in only the gfi outlets work not the radio.
Mines similar, outlets work but radio will only work on battery. Radio will not work on mains only. Charger works at same time so ok. SORTED IT TONIGHT. Inside the charger inside the box there is a fuse (240v 2A) I think, tiny radio fuse. Changed that tonight and radio now works on mains only or battery. Very awkwark job but better than watching a load of cr** on tv. Hope this helps someone.
Aug 12, 2009 | Bosch PB10-CD Radio/CD Boombox
47 people viewed this question
 Grubhead
Grubhead
