Question about Garden
I have a snowblower (MTD #195-990) that attaches to an MTD tractor #145-995. I have modified the snowblower to fit on a simplicity, however, I did not realize that the motors in the two tractors were installed in the opposite directions. Thus the snowblower is running in the wrong direction. I would like to get a schematic of the snowblower so that I can try to get another gear box made to have the snowblower operate in the proper direction. All it will take is another two gear gear box to fit on the bottom shaft of the existing gear box. I then can shorten the jack shaft to make everything operate correctly. So, I would like a schematic of the snowblower and/or the name of a place that sells or makes a gear box that I need. Thanks.
  • 109 Answers
SOURCE: 18.5 hp MTD lawn tractor has some type of
When the back wheels are on the ground...can you push or pull the mower??
If not, the brake is jammed and needs to be repaired/replaced
Posted on Apr 16, 2009
  • 376 Answers
SOURCE: how do i remove the blades on a mtd 42' lawn
Unscrew the 15/16 nut holding them on
Posted on Jun 20, 2009
  • 273 Answers
SOURCE: Clutch Malfunction and Adjustment
check clutch cable it could be either stretched or snapped if not you need a new clutch
Posted on Aug 12, 2009
harlan301
  • 205 Answers
SOURCE: which snowblower attachments will fit my lh1000
go sears web site, typ in your model number it well give you attachment part number if there is on emade for your unit. not LT can take blower attachments. its more likly you have a polune or AYP unit
Posted on Oct 13, 2009
BuzzFlewhart
  • 655 Answers
SOURCE: MTD Snowblower starts good but runs very rough
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
Posted on Jan 26, 2010
What is required to attach a MTD Snowblower model 190-032 to a ty4000 lawn tractor
That looks like a Cub Cadet part # for the Snow Blower.
You will absolutely need to customize a Belly bracket and Mule drive. Possibly find a Cub Cadet belly bracket and modify it to match your mounting points on the TY4000
Oct 13, 2014 | Mtd Housing Auger 26" - 684 04071 4044
Attach snowblower yardman lawn tractor
most likely not unless...
Oct 03, 2013 | Garden
Does craftsman snowblowers fit mtd products
usually they do You can check the first 3 numbers of the model to see who made the machine for sears.
Nov 13, 2012 | Garden
What snowblower attachment will fit on a 1992 Mtd tadesman gt 1846 lawn tractor.
don't put one on all snow blower on riding mower don't do very well and you will aways see the for sale for that reason
May 27, 2012 | Mtd Garden
Mtd snowblower yardmachine 3 hp/21"
if you are standing at the handles of the snow blower , kneel down there should be a sticker on the drive cover between the wheels , hope that helps
Jan 13, 2011 | Mtd Garden
I'm trying to attach a Model# LST42 snowblower to a 26hp Craftsman riding mower. Was wondering if you had a manual for the installation & where i could get it
Here is the manual for the snowblower; http://www.odref.com/agri-fab/SnowThrowers/LST42.pdf
You may want to call Agri-Fab at (800) 448-9282 first to make sure your snowblower has the correct brackets to fit the Craftsman tractor.
Have the numbers off the snowblower nameplate and the model number of your tractor (it's under the seat)
Oct 13, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Which snowblower attachments will fit my lh1000 42" craftsman lawn tractor
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
241 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
