Question about Panasonic Televison & Video
How do i reset panasonic 1080i hdtv bbe? closed caption stopped working and last time this happened was instructed how to reset
  • 14 Answers
SOURCE: I can not get closed captioning on my vizio VO42L
If you are using a HD cable box then this would be setup in the cable box itself.
Example:
With a Motorola Cable box, you would turn it off and press the menu button (with the receiver off and TV on). This will bring up a menu that will allow you to adjust your digital closed caption settings.
If you do not have a Motorola cable box that I would refer to the manual or call the cable company.
Posted on Apr 05, 2009
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
SOURCE: Panasonic 1080i HDTV 52 in. will not turn on
Can i use a wii game system with a panasonic 52 inch 1080I hdtv?
Posted on Aug 14, 2009
SOURCE: Cant turn off closed caption
I have this same problem...TC-P42X1...can't turn off the closed captioning
Posted on Aug 29, 2009
Luisjhernand
  • 84 Answers
SOURCE: panasonic hdtv model 1080i manual
Go to panasonic's website at www.panasonic.com and click on televisions. Then click on the Get Support tab. Then enter the model number for your television and you should be able to pull up the manual that way. Hope this helps!
Posted on Dec 21, 2009
I have a Panasonic HDTV 1080i TAU BBE projection TV,I can't get a remote to work with it.
Check first to see if remote works---most shops or Radio shack have a remote tester---point remote at it and push a button and tester will indicate if remote works----some digital cameras will also work for this.
If remote is good either a problem with the remote receiver on front of set or the remote circuit inside the set.
Mar 18, 2012 | Panasonic Televison & Video
I Have a Panasonic HDTV 1080i. I tried to turn it on today but the power button just blinks yellow. What does that mean?
The blinking power indicator is actually identifying the ircuit which is stopping the set from working. How many times is the light blinking? Please respond to this sme post for assistance.
Sep 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Hi!!! my Tv is a Panasonic HDTV 1080i BBE High definition this is not a flat screen, the problem that it has is that the screen is not working well it looks like bouble imagen, what can I do?
I have never heard anybody refer to their tv as looking like a "bubble image" in the 15 full-time years that I have been a television technician, but all I can assume, is that you have a convergence problem, and you will need to replace both convergence ic's, and possibly some resistors. Approx. cost to repair by proffesional would be around $300.oo.
Nov 02, 2010 | Televison & Video
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic HDTV 1080i Lamp out Panasonic 1080i 42" HDTV - - saying "lamp needs to be replaced, reset lamp" - - what does this mean and how do I fix it??
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
Jun 01, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic 1080i HDTV 52 in. will not turn on occasionally. Is there a hidden reset button?
Apr 10, 2009 | Televison & Video
Panasonic flat screen can't turn off closed captioning...help...
Here's the solution...solved last night...And I'm not stupid, but Comcast is...
Our Comcast box has a flaw so says the tech support after 2 hours on hold...As much as I don't like Comcast, I have to say the English-speaking tech support person is a miracle worker...I thanked him over and over again...
If you have this problem with an HDTV and Comcast, try this: Press the power button on your cable box as soon as you release the button press the menu button twice.
You'll see a "secret" menu on your screen.
If it flashes by and doesn't stay, don't worry...
Repeat the process...Sometimes it takes 10 times or more to work (you can also try holding the menu button for 5 seconds after you release the power button).
When you get the screen use your arrow keys on your remote to select "disable" on the closed captioning option...Click ok on your remote and press power on your box.
Best of luck to anyone stuck with closed captioning...Hope this helps! Jen
Aug 04, 2008 | Televison & Video
Closed Captioning
Does this happen with a HD cable box and does it happen with a DVD or VCR playing on it?
May 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
