Question about Microwave Ovens
It was cooking food, then poof, everything quit. No clock, nothing, as though the circuit breaker had blown. Circuit breaker had not blown. Does this oven have its own fuse?
    Genius:
  • 1,341 Answers
This is the sound of an internal fuse or transformer which had blown This will require more expertise to fix.
Posted on Dec 10, 2009
Kenmore microwave 85609 has a 5E code on it
test this steps and fix it. God bless you
  1. Power Issues
    • If your microwave oven won't come on, ensure that the power cord is plugged into an outlet and that the power is on. Replace any blown fuses, and reset a tripped circuit breaker. If the microwave won't run, see that the door is completely closed and that nothing is stuck in it. Ensure that your door is not broken. Replace if necessary. See that you have not started the timer as opposed to the cooking function. Press "Start/Enter" to start your microwave.
    Clock
    • Your display will flash if your power goes out. You must reset the clock. If you do not hear a tone at the end of cooking, ensure that you have enabled the audible tone. Also check that you are using the right command. If your power goes out while your food is cooking, you must reset both the cooking time and clock.
    • Sponsored Links
    Cooking
    • If you see sparks while you are cooking, remove any metal objects or plates with silver or gold trim. If your food is taking too long to cook, ensure that you have selected the correct power level for the food item. Remove any other appliance from the 20-amp circuit line. Additional appliances on the same amp will draw too much power away from the microwave. Also ensure that you have selected the correct food item in the preprogrammed menu. Each microwave has its own error codes. Always read your manual to determine what the error code means. Examples of error codes include "E-11", "E-12" and "E-13." This means that you have a defective sensor, and you must get your microwave serviced. The "SE" error code indicates an issue with your control panel.
    Additional Problems
    • You may hear gear noises, especially a humming noise; the fan will automatically come on while your food is cooking. If your turntable plate makes noise, first clean it, and then see that it is positioned correctly over the roller ring. If your nearby appliances are experiencing electrical interference, move your microwave farther away to correct this problem.
Jul 22, 2013 | Microwave Ovens
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Wife was cooking food, she says she heard a big pow and saw a blue light in the MW. Now everytime we turn it on it jumps the breaker. Everything else works fine.
It sounds like the Magnetron that produces the microwave energy that heats the food has failed and shorted out which is triggering the Circuit Breaker due to the overload. You could try taking it to a repair shop, but with the cost of labour and parts these days, it is probably more economical to buy a new oven especially if it more than 5 Yrs old..
Feb 26, 2011 | Microwave Ovens
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
The microwave unexpectedly turns off at random times during cooking. The clock face and everything dies. It is then a random amount of time (5-30) minutes before it comses back. It is not the circuit...
You could try a new plug just in case, next the fuse inside or thermal cut out could be @ fault, could be the cable transformer end as it enters the micro.....
Apr 19, 2010 | GE XL1800 1100 Watts Microwave Oven
We were cooking a dish and stopped it at the mid point and to add some sauce and it would not restart. Clock and everything is out. Everything esle in house works, no circuit breakers were off. The Jenn...
The same thing happened to ours last night. We went to add another minute of cooking time and realized the oven was dead - no clock, no display of any kind, and no more cooking!
I've verified the power outlet is OK. Ideas???
Feb 19, 2010 | Jenn-Air M170 Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Was heating up food and all of a sudden nothing works on the microwave, nothing, clock, light, buttons, nothing..
sounds like your circuit breaker kicked or your fuse blew. go to your electrical panel and see.
Apr 21, 2009 | Whirlpool MH7140XF Microwave Oven
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
