Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
No picture on samsung lcd tv
Picture just went off
left a blue screen but the sound was still playing
  • 16 more comments
  • Anonymous Jan 31, 2008
    have same problem and cant get good tech support. samsung sucks
  • Anonymous Feb 08, 2008
    I now have a blue screen with sound. It worked a month ago. I can play a DVD under 'composite' with no problems, but the satelite channel is blue with sound only. I'm wondering if it is the tuner. From what I can tell it only has an NTSC tuner. I called tech support for the dish and all settings are correct.
  • Anonymous Jun 14, 2008
    Have a Samsung 52" LCD - have sound but no picture. Checked cables - all good connections, DVD plays sound but again - no picture, Any suggestions?
  • vandanab Jul 21, 2008
    I am also facing the same problem. SOund is there but no picture. It gives just a blank screen.
  • Anonymous Jul 24, 2008
    After
  • Anonymous Sep 25, 2008
    I have the blue screen also with sound. Have not tried anything but turning the television off and on and no luck. Too be blunt this sucks!!!!!
  • Anonymous Nov 08, 2008
    I have great sound but no video on 40" LCD panel. After reading this I realize that is common after 2 years. I plugged in another TV and it worked fine with the same cable connection so I know it is the TV.
  • kadiart50 Nov 10, 2008
    46" Samsung Flat Screen HD TV with sound and no picture-less than two years old. How much to fix this problem?
  • preetam20 Nov 21, 2008
    I am having the same problems.... The problem happened to me 7months back. Then I called the Samsung Technicians...But while they were present nothing happened so they refused to touch the LCD...But now again after running smoothly for 6mnths the same problem is persisting....I am feeling very frustrated.....
    Tell me what to do.....
    What have u guys done ????
  • Anonymous Nov 29, 2008
    I HAVE A BLUE SCREEN (42" SAMSUNG LCD FLAT PANEL, PURCHASED JULY 2006) NO PICTURE. BECAUSE IT IS HOOKED UP TO A CABLE BOX, TUNER AND EXTERNAL SPEAKERS, I AM NOT SURE IF THE TV HAS SOUND OR NOT.
    SAMSUNG 42" FLAT PANEL LCD. BLUE SCREEN (WITH SOME PINK), NO PICTURE
  • gaford Dec 20, 2008
    Same problem - 2nd TV - first one Samsung replaced - 2nd one they repaired - and now happening again. I'd say Samsung is putting out some fine lemons - can't endorse the quality of their TVs, though.
  • seadooo98 Dec 23, 2008
    My samsung 46" LCD recently lost its picture but has sound. This is the second Samsung product that **** the brick within two years. Thanks for garbage Samsung!. They make their products to break, i'm convinced. I now have a 46" radio. Word to the wise. Buy SONY!!!!!!!!!!!!!!
  • parkhead Jan 20, 2009
    I have a 3 year old 32" Samsung with no picture only sound
  • Anonymous Jan 21, 2009
    was watching my Samsung 32" HDTV, switched channels, and the screen is now just a light blue... cable info., sound, DVD information works... everything but the tv picture... any idea what's up... thanks... Ted R.
  • Anonymous Mar 21, 2009
    I have a 4 yr. old Samsung LNR-328W that quite suddenly lost it's picture. There is audio only,with a solid blue screen, no flicker, no lines, just solid blue. I noticed the HDTV was running hot to touch on rear near vents. I am currently waiting for a local TV repair tech (authorized for Samsung) to come to house and give a free estimate. If the repair is more than TV is valued (it is 4 yrs. old) then I'll ditch it for a Sony Bravia BR6 series.
    I bought this based on previous experience with Samsung products and thought they were good quality. I bought this model new, so I expected it to run well for many years.
    I'll update the post once I discover the reason and possible solution.
  • buzzreno Apr 24, 2009
    Ya ya, a 40 " LCD Samsung with blue screen with sound. Bought it with the extended warranty in 2005. Geek Squad on the way! Sounds like enough people are having the same problem that a class action lawsuit could get us some money back.
  • Anonymous May 15, 2009
    I also have this problem: sound but no picture.
I have the same problem. I brought a Samsung 46" in July 07 and on Jan 8, 2008, video went blue.
I called Samsung and sent out technician and they replaced the motherboard.
Two hours later, same problem occured. I called today and Electronic Company thinks I have a bad LCD panel.
Posted on Feb 16, 2008
    New Friend:
I have a Samsung TV HD/LED/Wifi bought in 1/12, all good today the screen went off but sound OK. Unplugged & plugged few times but the problem still exists. I have called Costco and expect technician call by Monday. Any ideas for a quick fix?
Posted on Nov 23, 2013
I have the same problem. Given that it happens only in the HDMT mode and I can watch TV in Ext.1*** mode I think the fault is in Box. I called Virgin in Summer and they changed the BOX - no change. Their technician said it is the scat cables fault as they tend to overheat when old and needed changing- so I swapped with the spare ones I have - No Change!! I have not decided to but the gold £50 ones as I do not think they will be 10x better than the £5 ones I have - if you do share with us the results. So the problem persists. Since I can watch TV as above*** I only have the frustration of recording blank occasionally when this happens when time-recording!! By the way I love my Samsung.
Posted on Nov 15, 2008
The Samsung authorized repair Technician diagnosed my Samsung LCD HDTV. Initial symptom was suddenly having audio only and solid blue screen. He said the problem was well known to be caused by a faulty video board. He has seen this same issue many, many times. The power supply checked out okay and the cabling was good. The signal coming from cable box was strong. The motherboard was good. Problem was the video board.
Cost to repair / replace video board is $450.00 which includes parts and service. Estimated repair time 4 days from local NJ vendor.
I consider this a good deal. Now I'll enjoy it for another 3-4 yrs. before upgrading to a newer HDTV. This is the only issue I've had with this Samsung LNR28W purchased in 2005. With the economy as it is, it's wiser to repair a good, sturdy unit than to buy a new model now being made with cheaper materials (that's one reason the costs have come down).
Posted on Mar 21, 2009
  • Samsung Sux Sep 18, 2010
    You consider a $450 repair for a recurring problem a good deal. The TV repair guys must love you.
2 Suggested Answers
6ya staff
SOURCE:
vinhson65
  • 257 Answers
SOURCE: blue screen
Did you see the back light at the back. If yes, the problem may come from T-Con board. Try other source like playing DVD AND If THE SAME PROBLEM HAPPEN, you may think of the main board defective.
Posted on Aug 18, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung hdtv- sound but no picture
Your backlight inverter is bad. The backlight inveter is the board that turns on the backlight on the tv so that you can see it. You would have to open up the tv to get the part number. it is usually on the far left or right of the tv attached to teh screen.
You can get get parts for this tv at www.interliquidparts.com
Nov 20, 2011 | Samsung LN32B360 32 in. LCD HDTV
Watching TV and it suddenly turns off just like if you had the remote and shut off the TV. We set in amazement for a few seconds and then we turned the TV back on. We had sound but no picture. It was a...
Tv turn on now,does it have a flashes of picture only a few second than dies and than have only sound left?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards are one to the left one to the right both must be replace.The 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 LCD inverter boards for the replacement.
Mar 02, 2011 | LG 50PJ350 50 in HD-Ready TV
Black screen on lcd
Probably need a Main Board. Take it to an Authorized Samsung repair shop for troubleshooting. T-con would be another possibility and I've even seen the LCD Panel bad on this model
May 12, 2010 | Samsung LN-T3253H 32 in. LCD Television
Blue screen
Aug 15, 2009 | Samsung Televison & Video
No picture screen is blue
If you use RF cable, need to change brand new cable.
But, before that need chck the status of cable connector.
Feb 01, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
10,571 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
