Question about Ridgid 10"Wet Tile Saw with Laser and Stand
On/off switch is stuck in on position - Ridgid 10"Wet Tile Saw with Laser and Stand
  • 152 Answers
So is mine.... you have two choices... either take the switch out and try to repair it ( not easy and often un repairable) or replace it with new switch. I've been plugging and un plugging mine for the two days i've needed it.
Posted on Dec 13, 2009
Monitor On/Off Button Stuck
Get a stiff paint brush and cut the bristles down then run the bristles around the switch. it will (should) clear any debris that is causing the switch to stick.
Apr 01, 2013 | Computers & Internet
Air regulator valve on dash for heat and AC stuck in on position. Ram 2500, 2004.
The most common problem is a stuck or faulty blend door under the dash.
Feb 22, 2013 | Cars & Trucks
Wipers come on when ignition switch is turned on
my guess would be that either your wiper relay contact is stuck on the close position or your wiper switch is stuck on the on position.
Dec 03, 2012 | Ford Econoline Cars & Trucks
My vehicle will turn over but wont start
Trouble Code: P1391
CKP Or CMP Sensor Signal Intermittent
Possible Causes:
Camshaft Sensor is not installed properly . Engine valve timing is not within specifications. Perform a CKP and CMP Sensor relearn with the scan tool . Tone wheel or pulse ring is damaged .
Trouble Code: P1899
A/T Park Neutral Switch Stuck in Park Position or In Gear
Possible Causes:
P/N switch signal circuit is open between the switch and PCM . P/N switch signal circuit is shorted to Sensor or chassis ground. P/N switch ground circuit is open (at the switch mounting point) . P/N switch is stuck in P/N position, or stuck in Drive position . P/N switch is damaged or has failed. PCM has failed .Here is what is listed for these codes.
Aug 25, 2012 | 2003 Chrysler 300M
Can anyone tell me what does the following codes mean for my 2006 Ford F-150 Pick up 4.6 litre The codes are as follows: P210406, P2111, P2112, and P2135.
code p2111 throttle actuator control system actuator stuck open. throttle actuator control system circuit malfunction. brake vacuum implausible signal. code p2112 throttle actuator control system actuator stuck closed.throttle actuator control system circuit malfunction. code p2135 accelerator pedal position sensor switch a b voltage correlation. throttle position sensor switch a b voltage correlation. electronic throttle position sensor switch 1 implausible signal. did not see code p210406 that code too long.
Apr 15, 2011 | Ford F-150 Cars & Trucks
Switch will not change between on and off. It is stuck in the on position.
Please mention the product/device so that we have an idea. It can be that the switch is stuck up and is faulty or that there is obstruction to the switch. Use some degreasing/cleaning spray on to the switch as you gently move if back and forth. this might clear the obstruction.
Mar 21, 2011 | Health & Beauty
My macerator pump is staying on
Depending on the model, the level pressure switch may be stuck in the on position. Or if it runs on a pressure chamber then the membrane could be warped, if warped then it will need to be replaced, a piece of solid may be stuck under the membrane keeping it in the on position or the micro switch may be stuck in the on position.
Oct 21, 2010 | Saniflo & Saniplus& Macerator Pump
I have a 2002 saturn l22 and I was floored passing a car and the ac compressor stopped working and won't come back on. Where's the WOTC switch located?
possible throttlr position switch stuck in wide open position, try removing it and see if it is stuck (switch mounted on side of throttle body)
Aug 17, 2010 | Saturn L-Series Cars & Trucks
The shut off switch is stuck to the on position
This sounds like you have an internal problem with the electrical switch. I would recommend you take it to a vacuum dealer who has experience with this model. This is a relatively simple reapir for a pro shop to handle.
Jan 13, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Ridgid 10"Wet Tile Saw with Laser and Stand Logo
409 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
