Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
My heater will fire but after usually after 30 but then cuts out
My heater will fire but after usually after 30 seconds I hear a small clank and then it cuts out and the pilot goes out. I also have a little trouble getting the pilot lit but I usually can.
    Problem Solver:
  • 17 Answers
Could a bad high limit switch on the heat exchanger .
or most likly a flame proofing switch in burner
Posted on Dec 10, 2009
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
Spark plug fired,( Sears -30,000 BTU) starts and runs for approx. 30 seconds, then cuts off. The reset button does not reset for restart for about another 20 - 30 seconds. Then the unit will restart...
check and see if the heater has a high temperature limit switch. if it does it will shut the machine off until it cools down.. just replace it with a new one.
Jan 31, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
What makes the heater start up then cuts off after about 5 seconds with a little of kersone running out of the front of it
This is normal. It has a time limit to fire off. The heater will cut off if it does not light.It sounds like it is never lighting up. Check your ignition source. I am not sure if you have a spark plug type or a glow bar.
Jan 03, 2011 | Reddy Heater-30-55,000 BTU Variable
Heater fires but cuts out again after 30 seconds
sounds like flame sensor.try taking it out and polish with steel wool.flame sensor is a rod that is in flame with a single wire going to it.If there is no flame sensor,check limit switches,but they usually have to be reset when triped.high limits usually reset when cool.check flew for blockage if theres air conditioning,check a coil could be dirty.if every thing else is ok then control board is bad.real hard for nubies to diagnoise.
Dec 29, 2010 | Heating & Cooling
Reddy heater cuts out after 30 seconds
this problem is common with this type of heater and usually means that the fan is not pushing enough air over the heat exchanger and is tripping the high limit switch.check the fan
Dec 08, 2009 | Reddy Heater 60,000 BTU Kerosene...
Unit fires for 30 to 45 sec then cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 13, 2009 | Reddy Heater-30-55,000 BTU Variable
All pro 115k
This sounds like you will need to replace the thermostat!
That should fix this common problem!
Dec 20, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Nov 02, 2007 | Reddy Heater-30-55,000 BTU Variable
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
139 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
