Question about Kicker ZR360 Car Audio Amplifier
I have a Kicker ZR360 CLASSIC AMP that puts out very little sound until I push on the crossover module. Is something wrong with the crossover module or a connection on the amp itself?
  • carpenter020 Dec 10, 2009
    Thanks for the response.
    I will have someone look at it.
  • Perry Babin May 11, 2010
    These amplifiers have problems with both the crossover modules failing and the solder connections failing between the riser board and the main board. If you can push on it and it plays normally, the solder connections on the main board are likely your problem. You'll need to have a technician check it and resolder them if necessary. Let me know if you have any other questions.
    Novelist:
  • 92 Answers
THERE IS AN ISSUE WITH THE FEMALE CONNECTOR THAT IS SOLDERED TO THE PC BOARD THAT ACCEPTS THE CROSSOVER CARD. IF THE CROSSOVER IS PUSHED WITHOUT CARE, IT EVENTUALLY STARTS TO HAVE POOR CONTACT. THE CONNECTOR MUST BE REPLACED. YOU SHOULD BE ABLE TO FIND MY ADD FOR REPAIR UNDER ZIPCODE 70360. I AM NEW TO THIS FORUM AND DON'T YET KNOW HOW TO LINK TO MY ADD ON THIS SITE. YOU SHOULD BE ABLE TO FIND IT BY SEARCHING MY LOCAL ZIPCODE THOUGH. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE......V
Posted on Jan 06, 2010
My zr360 when i turn on the radio turns the subs to full pulsing bass very loud and there is no control. have to shut off the radio to stop it
yuor amp has an internal power supply problem,contact eric @ Capital Audio & electronics Repair 850-339-1130 we repair all namebrands & all models
Mar 16, 2010 | Kicker ZR360 Car Audio Amplifier
Just hooked up my new kicker 10 cvrs to zr360
Your light could be dimming because of your altinator or you battery. You need an upgraded altinator to feed yor system what it needs. If you can, talk you your local car audio expert and never go wal-mart or "Anything" kind of stores for car audio advice.Watch this video. This guy has a kickass system with 1 18'' and 3000 watt amp. Put the vid to 52 seconds.
Jan 18, 2010 | Car Audio & Video
Kicker zr360 in protection
unplug rca,disconnect spker turn on amp if light goes away start connecting with one rca and one spk wire and you will find the problem should go away '''''''make spk polarity is wright
Apr 07, 2009 | Kicker ZR360 Car Audio Amplifier
Kicker 550.3 amp will not power up
do u have the remote wire hooked up to the (rem) spot usally inbetween the pos and neg?
Mar 15, 2009 | Kicker ZR360 Car Audio Amplifier
Your amp
Do you have a remote wire set up? if not, you need to run one from your deck so that it can trigger the amp to come on.
May 14, 2008 | Kicker ZR360 Car Audio Amplifier
Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Dec 28, 2006 | Kicker (ZX750.1) Car Audio Amplifier
Kicker zr360 amp
Double check that your ground wire is connected to the ground terminal, make sure the ground wire is not broken.
Oct 11, 2006 | Kicker ZR360 Car Audio Amplifier
Kicker ZR360 Car Audio Amplifier Logo
232 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
