Question about Whirlpool LER4634J Electric Dryer
How do I put a heating element in a dryer? - Whirlpool LER4634J Electric Dryer
    Scholar:
  • 68 Answers
There are a few differant styles, give me your model number and i will see which one you have.
why do you think it needs an element? if its not getting hot you may have a cheaper and quicker repair than an element
Posted on Dec 10, 2009
Whirlpool Electric Dryer LER4634PQ0 only blowing cold air
Posted on Dec 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: New Element, still no heat
Posted on Jan 07, 2009
hogwalla
SOURCE: replaced heating element in dryer. will not run.
You have a bad (thermal limiter). It's like a fuse one time shot, it stops all of the control power to the dryer. Try testing it with the dryer unplug use a ohm meter across the leads. It should read some type of a reading, if it reads OL it's burn out.
Posted on Jan 16, 2009
  • 686 Answers
SOURCE: dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Posted on Apr 08, 2009
SOURCE: preforma electric dryer wiring on heating element
called a local fixit man he told me how to for free
Posted on Jun 06, 2009
heatman101
  • 43501 Answers
SOURCE: my amana dryer wont put out heat. I've taken the h...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
My dryer will not heat up
hi friend,
Step 1 The most common cause of a dryer not heating is that the air duct gets clogged. This can cause a fire and should be cleaned out about once every couple of months. Take the air duct off from behind the dryer with a screwdriver and take the other end off near where it goes into the wall. Run a hose through the air duct until all the junk and lint from inside gets out. Let it sit in the sun for about an hour to dry then hook it back up. Try the dryer out to see if it heats again.
  • Step 2dryerrepair_thumb.jpg Dryer thermostat The dryer's thermostat can also be the cause of it not heating. Locate your dryer's thermostat and take it out with a screwdriver. Take your multimeter and set it to the resistance setting. Put one lead on each terminal. You should get a reading of 0, or -1, which means infinity. Any other reading than this means the dryer's thermostat is bad.
  • Step 3dryerheatingelement_thumb.jpg Next, test your dryer's heating element. Heating elements cary in what they look like but you should see some sort of coil of wire like a toaster. You can do a search online for your dryer's heating element. Once again, set your multimeter to resistance and take the heating element out. Put one lead of the multimeter onto each terminal of the heating element. You want a reading that is not 0 or -1. If you get a 0 or -1 your dryer's heating element is bad.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Try walking into your local hardware store and asking them if you get stuck.
    • Make sure you un[plug the dryer before you start to fix or repair it.
    hope this helps u
    please rate me..................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Dryers
    Heat elament is out
    1. Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
    2. Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
    3. Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
    4. Unscrew the screws holding the element in place and pull it out.
    5. Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
    6. Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
    7. Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
    Sep 23, 2009 | Washing Machines
    We have a Kenmore Gas dryer it runs but it doesnt get hot.. any ideas what it could be?
    The heating element is most likely burned out. Try ordering a new heating element for your dryer and calling a repairman to put the new heating element in.
    Jul 15, 2009 | Kenmore Dryers
    Dryer not heating...tumbles and blows OK - is 2 30 amp fuses enough
    ELEMENT IS BAD NEED TO HAVE A SERVICE TECH REPLACE THE HEATING ELEMENT
    May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
    Dryer won,t heat, put in new element and still won,t heat.
    Apr 08, 2009 | Dryers
    My maytag electric dryer will not heat up. it's a de107
    Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
    Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
    Jan 07, 2009 | Whirlpool LER5636P Electric Dryer
    Whirlpool LER4634J Electric Dryer Logo
    516 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
