Question about GE Ovens
MY XL44 GAS OVEN IS HEATING UP BUT IT DOES'NT STAY AT THAT TEMPERATURE CONSISTANTLEY. I HAVE TO SHUT THE OVEN OFF AND THEN PUT IT BACK ON PRE-HEAT.i NOTICE THIS THE MOST AT TEMPS BELOW 400 DEGREES. MODEL# JGP3OCEALCC
    Scholar:
  • 68 Answers
Your model number is not showing to be valid, please double check it.there are a few differant issues you could be having.
  1. the bake ignitor is going bad and its on the edge of total failure
  2. the sensor may be developing a short in it and the odds of the short occuring increases the higher the temperature
you can look up the parts here http://lartoday.com/order_parts.htm using your model number
Levi
Lebarchrigen Appliance Repair
www.lartoday.com
Posted on Dec 10, 2009
It seems my plain fan convection oven takes significantly longer to pre-heat to 350 degrees when in convection bake.
I would check the oven sensor it may be defective
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
Apr 07, 2015 | Kenmore Ovens
Oven is taking to long to heat
look for the temperature sensor inside the oven cavity in the upper left or top center of the upper oven cavity,its will be a silver or copper colored rod about 1/4" by 2" to 6" long this rod senses the oven temp and cycles the heat to the oven
Jun 03, 2012 | Kenmore 30464 / 30465 / 30469 Gas Single...
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Pre-Heated my oven, it beeped and I put muffins in. They began to cook and suddenly oven lost heat. When I try to pre-heat now, it clicks as if it is pre-heating but I am getting no heat. I have checked...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 10, 2010 | Kenmore Ovens
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
XL44
Jun 09, 2010 | GE Ovens
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
OVEN TURNS ON BUT WONT HEAT UP.
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
Oven Stops Heating
try it on broil and let me know what it does i dont think its a sensor as they check their selves and set a code most of the time
Feb 15, 2008 | Ovens
Ovens Logo
55 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
