Question about Garden
Have an old 5 hp. ariens.fires and turns over,tried starter fluid cleaned carb. seems like it turns alot after pulling cord weak or no combustion
  • 47 Answers
Sounds like a broken connecting rod pull the spark plug out put your finger over the hole then crank it over to see if you have compression it should push your finger just make sure you dont touch the coil wire in the process
Posted on Dec 10, 2009
How to start a 1979 30 hp evinrude
Hey Norman,
There are only three things required for a internal combustion engine to run.
I have one issue.. I DO NOT see a 30HP built in 1970 - 1983?? They are 35HP. The first 30HP I see was built in 1984.
1. A good timed spark (New spark plug) - The correct one. (CHAMPION QL77J4 - qty. 2)-1984 30Hp.
2. A proper fuel air ratio (with yours also the proper oil/gas mixture)
3. Good compression (for your engine - w/carb wide open 120psi)
A service manual will help you ( MarineEngine.com)
Grab a buddy to help you do these..:
1. Make sure your spark plug will fire. Hold the spark plug hex against the head and have your buddy pull the cord..it should fire a juicy blue spark,, BUT - a healthy orange spark will work. If there is no spark..(double/triple check this!!).. stop here until you get a spark!!
2. Have the carb cleaned and set..by a competent professional (one this old can be fixed by a trained professional motorcycle mechanic -its the SAME SIMPLE type carb - I repair "carbed" outboard engines too!).
3. You can hold your finger in the spark plug hole TIGHLY and have your buddy pull the rope.. it should BLOW your finger off the hole.. if you are not sure - get a compression gauge - use the 1/2" depth threads, screw it in until the oring seats..put the throttle wide open - WITH THE SPARK PLUG REMOVED and AWAY FROM YOUR HANDS...pull the starter rope hard about 5-7 times!! It should pump up to about 115lbs.+ minimum!!
If these above items are correct.. you engine should/will run!!
Jun 12, 2017 | Boating
Motor quit put new gas, charged battery, checked oil still does not turn over- prior to this the engine would backfire prior to starting- I have checked connections-
Does not turn over or does not start? Does not turn over usually means a bad battery or starter. Or connections which you have already checked. There may be a fuse block or inline fuse as well. Does it have a manual pull start as well? Does this turn over the engine or is it siezed up, low/no oil.
Turns over but does not fire usually is spark or the fuel. Back firing would guess spark plug or carberator (air fuel mixture) If it turns over but does not fire, try putting in some Seafoam fuel system cleaner. This will get the varnish-gunking stuff out of the carb. Mix in your tank, turn over quite a bit to get it pulled into your carb bowl and into some of the carb port holes. Let it soak a while and then turn over again every so often to pull in new cleaner. If it starts at some point it will stink a little while burning the cleaner in the tank.
Make sure you have check the old fuel lines and and air vacuum lines for pin holes and cracks as well. Change the plugs. Make sure the air filter is clean. Change the fuel filter. Does it fire if you shoot starter fluid in the carb air intake, this would suggest a fuel issue, such as dirty carb, bad fuel line or fuel filter, or fuel pump.
Jan 09, 2016 | Ariens Lawn Tractor 42"" Riding Lawn Mower...
Torn down Yard Man wont start
Fuel related if you can get it to fire with starting fluid.
May 12, 2013 | Mtd Garden
Engine wont start
press the primer 5 or 6 times full choke and make sure idle lever is up a little when it starts take choke off one notch at a time then rev engine slowly
Dec 21, 2012 | Ariens Deluxe 28 Model 921022 St28le 2...
I have a 1990 ZX7 which has been sitting for several years. I cleaned the carbs air filter petcock and fuel lines replaced the battery and can get it to turn over but it will not start. I tried turning it...
Did you try starter fluid?
Pull your plugs & see if gummed up.
If so don't clean replace.
Now if it don't start pull the plug ground it to the bike with the wire on. Now try to turn it over and see if you have spark. Sounds like fuel is going in cylinders but no spark. The last time you tried. I think you got a combustion fire. And that was your bang.
May 15, 2010 | Motorcycles
Not getting fuel, burns only starter fluid
Ok, what you need to do is pull the bowl off the carburetor, and look at the nut that you took off to get the bowl off. There is a hole that goes through the bottom, and down the center, meeting in the center. This is a metering hole that allows fuel to go to the carb. If this gets plugged, then your engine will act exactly as you describe. Use a piece of wire/wire brush bristle to clean the holes, and clean it with carb cleaner or starting fluid. Check the needle valve on the float and make sure it's free while you're at it. You'll know; if it's free, you'll be getting fuel leaking while you're doing this, so I would clamp the fuel line with a pair of vise grips to that liquid gold doesn't get away once you've determined the status of the needle valve. Put it all back together, and you should be fine.
Mar 28, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I Have a Older 5HP Ariens Snow Blower. It Fires Up and Runs On Starter Fluid. Gasoline, NOPE. What Is the Proper Number Of Spark Plug to Use in a Ariens 5 HP Snow Blower. I Believe it is Gapped at .30 ??...
Gary, J19LM is a good fit.
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 24, 2009 | Ariens Garden
I have a 6 HP Ariens whipper snipper on two 18" wheels, it is about 5 years old and ran perfectly since new with no maintenance, this year wont start. fires but will not run. changed the fuel and plug...
Check to see if fuel is leaving the tank, the internal screen might be plugged up. Check the rubber fuel lines and if provided the in line fuel filter for flow. Don't always trust carb cleaners and compressed air to clean a carb., you might have to use a steel wire from a wire brush to open the jets and passages.
Jun 22, 2009 | Toro Lawn Mower With Toro Power Tools
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
