Question about Canon Elura 50 Mini DV Digital Camcorder
Canon elura 50 keeps rejecting the tape - Canon Elura 50 Mini DV Digital Camcorder
Tape door keep eject
Posted on Jun 27, 2012
  • 35 Answers
SOURCE: Elura 60
Hi, When you say you're "using a tape for a while", can you define "while"? The thing about these little cameras is that they don't like to re-use DV tapes. If you are recording over tapes that have previously been recorded on, then your camera could be fussy about that. You can clean the heads, but if the tape is dirty, then it will transfer that dirt back to the heads and youp;ll end up in the same position. The problem is, that the heads will wear out if you clean them to often. In the long run, it's best to use new, clean tapes. And when you are using the tape cleaner, make sure you are following the directions very carefully. NewMediaMan
Posted on Jul 09, 2007
SOURCE: Disabling the Auto-Off Power Function on Canon Elura Camcorder in Record Mode
Take the tape out. The Camera should stay on.
Posted on Apr 18, 2008
jerryg50
  • 1689 Answers
SOURCE: Elura 85
I am not the person who made any suggestion to you. I happened to see your post when reading on this site.
When this type of problem ocures in any of the camcorders, this means that there is usually a mechanical fault with the loader mechanism. Another cause can be that there is a sensor fault with either a tape position sensor, or with the electronics that operates with the sensors, and the tape loader mechanism. If there is a servo fault the loader will also be commanded by the uPC to eject the tape.
Because of the way the camcorder is constructed and its sophistication, this is not something you can fix yourself. The electronics are mostly all SMD technology, and the mechanical parts are very fine as like in a mechanical wrist watch.
I would suggest that you get in touch with the manufacture service rep to arrange to have an estimate for repair. The service cost is not cheap for these types of devices. The work is time consuming and the replacement parts can be expensive. Get an estimate for service before making any decisions.
You may find that servicing your unit when it is out of warranty may not be worth the cost. If your unit is more than a few years old, you must consider that it may pay to get a new unit.
Jerry G.
Posted on Sep 15, 2008
  • 18 Answers
SOURCE: my canon camcorder drive for tapes rejects tapes
I had the same problem. Checked the site and found a solution of dropping the camera onto a carpeted floor from about 1/2m to 1m. Thought that it was bullsh1t but was desperate and so tried it. worked a treat!!!
Hope this helps.
Posted on Aug 13, 2009
arian07gapa
  • 62 Answers
SOURCE: Canon Elura 100 tape will not eject. Pops out but
stockk up inside..
bring it to repair shop!!
Posted on Apr 07, 2010
Keeps rejecting mini cassette ...saying please remove cassette
try to see if the black rubber roller is in the right position before to insert the cassette. You can push gentile with your finger or a pen to see if is stay firm on the position. If is balance on right and left , this mean is missing a spring that keep the rubber roller in tension.
May 31, 2010 | Canon Elura 100 Mini DV Digital Camcorder
My tapes keep getting rejected
it could be a tight tape witch case it will just spit it back at you
the other thing it could be is the battrey is getting down
Oct 26, 2009 | Canon Elura 50 Mini DV Digital Camcorder
Canon elura 90: won't load tapes
Make sure the power is on this unit and you are pluged into a good source of power. The disk tray needs power to lower. A lot of tapes get loose in there case and need to be fast forwarded and then rewound completely in order to help spool them properly in their case. And what you are experiencing sounds a lot like this. It is also possible that you need to buy a head cleaning unit for your elura and run it in the camera for 10 secs and then try again. (Did you try this with a New tape? or just used ones?) We bought a small tape rewinding unit for around 39 dollars that helps us to rewind the mini DV tapes without adding wear and tear on our camera and it seems to help with the issue of loose tapes in the camera getting rejected as they won't wrap around the tape head as nice.
Dec 14, 2008 | Canon Elura 90 Mini DV Digital Camcorder
Elura 85
Jerry G.
Sep 15, 2008 | Canon Elura 85 DV Digital Camcorder
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Elura 50 record direct to SD card
There may be a YouTube video that will help with this
Jun 30, 2017 | Canon Elura 50 Mini DV Digital Camcorder
Condensation Detected ......... Remove the Cassette
People, I got the same problem like 5 minutes ago, but I fixed it. You have to REMOVE the battery while the camera is off, then wait 2 seconds and take it back inside. It works.
But I have an Canon Xm1, so I don`t know if it works for all of you guys, but good luck!!
benjamin_sm91@hotmail.com
Jul 17, 2006 | Canon Elura 50 Mini DV Digital Camcorder
Canon Elura 50 Mini DV Digital Camcorder Logo
137 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
