Question about GE WBSR3140DW Top Load Washer
The water will not stop filling up.It never start to wash.
    President:
  • 744 Answers
Hi, This will be one of two problems. Either the pressure switch is bad or the valve is stuck open. The way to figure which is: when the tub is filling pull the power cord out. If when pulling the power cord out the water stops it means the pressure switch is bad. The pressure switch can be located inside the control panel. It has 2 wires and a plastic tube sticking into it and is attached to the water level knob. If the water fails to switch off when you pull the power cord this means the valve is stuck open so you should replace the valve. This is located behind the machine and are what the hoses attach to. If you have any other questions please feel free to comment. Mike
Posted on Dec 10, 2009
    Scholar:
  • 68 Answers
Does the unit start leaking when the water level is only half way in the tub?
yes----the pressure switch hose has fallen off the tub and the machine cant read the water level if its off. if your capable of removing the front panel, you will see a clear hose towards the left on the tub. if it fell off then cut about 1/2 an inch off the hose and firmly place it back onto the tub where it belongs.
no--- either the pressure switch hose is clogged or the pressure switch itself is defective
let me know if this helps..
Levi Holiday
Lebarchrigen Appliance Repair
www.lartoday.com
4 Suggested Answers
SOURCE:
  • 958 Answers
SOURCE: fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
  • 5 Answers
SOURCE: Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Posted on Nov 19, 2009
  • 32 Answers
SOURCE: Will not start washing process.
Potential problems:
1. Your vacuum tube has simply come off. 2. There is a hole in your vacuum tube, 3. Or you have a bad pressure switch.
To check,
1. Pop the top open on the unit and raise it up (for specifically how to do this, I'll need need the make and model number). You may need to disconnect wires from lid switch, noting where they go to put them back. 2. Locate a clear rubber-like tube come from under the control panel and going down the the bottom of the tub where it is connected to a small nipple. If it is not connected there, reconnect making sure it fits snug. You're problem is solved. 3. If it is connected, disconnect it and gently pull the end of the tube to you. Inspect if for holes or cracks or cuts. If it looks good, put the end of the tube (you may want to clean it if it's dirty) and blow air in it, keeping the pressure up and listen for a click under the console panel. Try again. If you hear the click, listen for air escaping from tube, maybe a pin hole or more. 4. If you do not hear the click when air pressure is applied, you have a bad pressure switch and it must be replaced, assuming the tube is actually connected to the pressure switch under the control panel. 5. Replace tube onto nipple near the bottom of the tub and replace the top. Reconnect lid switch. 6. Take control panel off and insure vacuum tube is connected to pressure switch. If it is, remove tube and blow pressure directly into pressure switch. If you hear no click, the pressure switch is bad.
To help you further or help you find the part, I will need the make and model number.
Good luck, this problem is more simple than it sounds.
G
Posted on Aug 02, 2010
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Water doesnt stop when filling washing machine
There should be a "fill control" on the panel of the achine that lets you set the fill limit for wash loads ranging from small to large. Obviously, your fill control is not working
Oct 09, 2012 | Washing Machines
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Fill will not stop
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Washing machine trouble
You need to replace the water level selector switch. You can check the part at repairclinic.com
Jun 27, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
180 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
