Question about Sony KP-51WS500 51" Rear Projection Television
Picture flickers 2-3 times thjen tv powers off. Seemas to happen after tv warms up for 5 minutes
  • 834 Answers
Ver comon on the older sonys one of your CRTs is shorting out the tube are no longer avail i would suggest you replace this set
Posted on Dec 10, 2009
SOURCE:
No display on 32"hd lcdtv okano model ltv3204
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of spare parts + service charge. More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and size.
Oct 21, 2014 | Televison & Video
Every time i turn on my sony PFM-42x1 the screen flickers and blinks with colored lines all over it. at first it flickers very fast and as the tv "warms up" the flickering slows down until it stops all...
I have the same TV with the same problem. I am sorry that all the answers are so silly and basic. I just open up mine to check all the compositors to see if their are any Bulging or to see if anything looks damage. I will pull the Power supply and start checking the compositors. and let you know. I will look in other places first to see if I can get some REAL Answers. Poco Zocko Actor
Oct 13, 2013 | Sony PFM-42X1 Plasma TV
Sony pfm-42x1 flickering screen when turning tv on
OKAY I found the Problem!! Bad Caps Compositors. I Proved this in 2 ways. First I took off the Back(always make sure the TV is UNPLUG) In the photo above I put my finger on the capacitors. I found some that where NOT FLAT ON TOP(You can kinda see in the photo too). I could feel a little nipple on top.(Some times you can see if their busted open but not in this case) so I felt them and the bottom right and top left area in red in the photo where not flat. I took my dryer(My wife really) and warmed them up for about 2 minuets each then another minuet rotating back then forth. I leaned the t.v. up to lean on the frame and plug it in. I continued warming the capacitors up and in about 2 Min the T.V. has stop blinking. Much better then the 20-30 min. So the hunt for the Capacitors is on. It will be some work to get the boards out. If everything is done delicately The Soldor job is easy for me. I am going to buy the 8 but replace 1 board at a time until the TV works and put the other on the side for next time or put them up on E-bay. I hope this helped Please like if this helped you. ea0a96a3-fb82-4ec0-89f4-76b4080e9c6e.jpg 1b190ebd-5d69-4553-a009-840d29ab4c87.jpg ab9b51d0-6e1d-4cce-b822-e80d0fde9163.jpg
Samsung LE40N87BDX picture flickers
check for a dry joints connector at the inverter board.
Jul 26, 2012 | Televison & Video
Picture has lines and goes black after warm up
Try unplugging for 2 mins. Or press power button for 30 seconds. Your Light in the tv might be shot.... happens every 5 or so years.
GOOD LUCK
CNBY
Jun 03, 2010 | JVC RM-C18G-1H Remote Control
FLICKERING PICTURE
Check power supply for the 24Volts connected to the backlight inverter ,bad caps could be the fault
Jul 20, 2009 | Sony Televison & Video
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
