Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
It runs for a little while and quits - Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
I went crazy trying to fix my heater. someone told me to check the fuel filter, access thru the side panel). i cleaned it out and now it runs like brand new!!!
Posted on Jan 09, 2010
Ready heater runs for a minute then shuts off
Posted on Dec 23, 2009
Why did my overdrive quit working on my 2004 mercury grand marques?
run the fault codes
indicates a problem od servo / solenoid
Jun 24, 2017 | Mercury Cars & Trucks
Polaris troubleshooting
Why do you want to ride more than 5 minutes? :)
I need a little more info, what happens when it quits, How quick will it start back? Does it backfire, produce black smoke...???
Jul 04, 2014 | ATVs
We have 78 Chev, with a 305 engine, It sometimes starts, and runs for a little while, then dies, Changed the fuel pump, did not help, Do have spark. It will start sometimes and will run for a little...
check that small black module under the distributor cap, these are heat sensitive and will quit working if too hot or quit working altogether.
Jun 13, 2017 | Chevrolet Cars & Trucks
Had moisture on top for a few days. Then just quit running. Turned it off, let it for a day, turned it back on, it ran for a little bit and quit again and now will not run at all.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 11, 2011 | Goldstar DH304 Dehumidifier
Fan quitting on unit
Maybe the room is dry enough so the humidity sensor is turning it off?
If not, maybe the thermisensor(fuse) on the fan motor is failing?
Jan 02, 2010 | Comfort-Aire BHD-501 Dehumidifier
73 vw quits after running about 2 miles
if I understand correctly the car starts and runs for a little bit then quits. if this is the case it could be a bad coil.start it and let it run till it stops then feel the coil. if its really hot thats probably your problem
Sep 13, 2009 | 2008 Volkswagen Beetle
Quits running after it starts to warm up under 1 mile
Try your ignition coil. That year model chevy has a dry running coil and it does not go out all at once. It will spark and run while cool but just as soon as the everything starts to heat up the resistance in the coil begins to build and it quits firing. After letting the vehicle set a little while and cool off it will fire off and run just fine untill it starts to heat up again.
Jul 20, 2009 | 1994 Chevrolet Suburban
Snowblower runs then quits
check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Dec 19, 2008 | Mastercraft Garden
Heating & Cooling Logo
226 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
