Question about Rancilio SILVIAespresso&cappuccino machine
Rancilio producing very very slow shots...even when no portafilter.
Have had the Silvia for about 3 years now with no major problems until this morning. Noticed it takes very very long for the shots to fill. I tried decalcifying the machine thinking that would take care of the problem. Cleaned all of the normal parts and when I had then unscrewed I turned on the machine to see and found still only a trickle of water coming out. I know the water is coming out much slower than it used to. The steam wand works great and the water comes out of it nice and fast. It makes me think it isn't the pump if this comes out really fast. Helpppp....
    Novelist:
  • 137 Answers
From your description i can conclude only 2 things:
  1. coffe grinded too fine
  2. pump pressure low
i think you can chek these 2 and have your perfect espresso again
Posted on Mar 31, 2009
Rancilio silvia suddenly expression is just gushing through and watery. Have tried finer grind but no better. Haven't changed anything.
First, I'm not a Rancilio tech but I have worked on similar models.
*** All service should be performed by a qualified technician. The following is for information only ***
* Usually one gets less water out of the portafilter rather than more (or faster). Check the amount of water on an empty shot. It should be between 1-1/2 oz to 3 oz (depending on your shot size) If this is a manual on/off shot then disreguard.
* Fast pour is directly related to the pressure setting (usually 9 bar), Coffee amount, Grind size, and Tamp (or compression). You can check most of it by following the many examples given on you tube. Water pressure is a bit harder as you will need a pressure guage portafilter.
* If your still having problems with fast shots then have your service vendor check and adjust the bar if needed.
Aloha, ukeboy57
P.S. Check if your using the right portafilter, There are many types used for different purposes; Pod, Capsule, Single, Double, Tripple, Drip coffee (Americano), Back pressure adjustable, ect.
Apr 24, 2018 | Rancilio Coffee Makers & Espresso Machines
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
I have a Silvia which is about 6 years old. Over the last few weeks, when I am brewing coffee, some water leaks around the portafilter. The portafilter is well seated and properly tamped. How do I approach...
Have you ever changed the brwe head gasket? It should be changed yearly at least. They get hard from the heat and won't seal. They should be soft to make a good seal. You can change it your self. I have left post on changing gaskets. Look for Silvia solutions.
Nov 14, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia - Water coming from behind into the drip tray when pouring a shot.
Correct
When you are finished and turn the pump off, the 3 way valve opens and relieves the pressure in the brew head so you don't get an explosion of coffee when you remove the portafilter.
Oct 26, 2010 | Rancilio Silvia Espresso Machine
I've tried grinds from a very fine to a coarser grind in my Rancilio Silvia, but the water is going through the portafilter/coffee too quickly. When I clean out the portafilter, there is too much dry...
Check the shower screen to make sure it is not damaged. Then try this get coffee ground from the store at #2, 3, 4 and 5 at least 1/4 pound each then use that to figure out what setting works best for your machine, also note the tamping pressure. Fill portafilter to rim then tamp to fill ring in basket.
Aug 24, 2010 | Rancilio Silvia Espresso Machine
Temperature problem
Keep portafilter in the head with no coffee in it at all times, preheat portafilter and cup before you brew a coffee.
Apr 25, 2010 | Rancilio Silvia Espresso Machine
Silvia leaking water
Hi
The solenoid valve needs back flushing the correct way with a espresso machine detergent like Cafiza, or Joe Glo. Place a 1/2 teaspoon in a blind basket. (don't come with Silvia). Place blind basket in portafilter and brew like making espresso, but run pump for no more than 5 to 10 seconds or until the pump starts to change tone (slow down). Stop the pump when either of these things happen or Silvia can be damaged. Repeat the pump 5 to 10 times leaving a 1 minute wait between cycles, or the suds comming out the 3 way valve turns pure white, with no coffee stains in the foam. Remove the portafilter and rinse then reinsert and repeat the cycles to rinse the internals. This should take care of the problem. If not you may have to replace the 3 way.
Nov 12, 2009 | Rancilio Silvia Espresso Machine
Waterflow/heat seems fine - but little/no extraction
Try running the gro;up without the portafilter in place, what does the water flowq look like: is it a nice strong flow or barely a dribble. If if is barely a dribble, backwash machine with purocaff and check shower screen, that may be clogged. If you have a nice flow then try adjusting the grind on the coffee grinder.
May 09, 2009 | Rancilio Silvia Espresso Machine
Rancilio SILVIAespresso&cappuccino machine Logo
319 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Marvin
Marvin
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
