Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Replacing a transfer belt on a Konica BizHub C500. How do you replace it? Or which side of the transferbelt unit do you remove?
    Champion:
  • 214 Answers
If i remember right, open right door, remove 2 tbu lock scews, open left cover, remove waste box and then remove tbu
Posted on Dec 16, 2009
Konica Minolta c284 error p-21
Code
P-21
Description
Color regist test pattern failure. • During pre-pattern detection, pre-pattern edge (start/ end point of effective area) is not detected within the pre-pattern search area. • During detection of regist pattern at vertical/horizontal direction, pattern edge (start/end point of effective area) is not detected within the pattern search area of each unit.
Causes
• Transfer belt unit • PH unit • IDC sensor shutter solenoid (SD2) • Front side board (FRB) • MFP board (MFPB)
Remedy
1. Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty. 2. Replace the transfer belt unit if the transfer belt is damaged. 3. SD2 operation check. 4. Replace the PH unit. 5. Replace FRB. 6. Replace MFPB.
Konica Minolta bizhub C558 Error Codes
Jul 16, 2018 | Konica Minolta Office Equipment & Supplies
Please how do reset transfer unit unit on konica Minolta bizhub c-252
for reset belt unit you have to change one fuse.
You need a new 50-80 ma fuse.
Remove the belt from the machine, the fuse is in the left side of the belt, under the left handle.
Replace it with a good same fuse.
For detailed guide see the link below:
Konica Minolta Service Manual
Aug 06, 2016 | Konica Minolta bizhub Office Equipment &...
How do I remove the transfer belt from c450 bizhub konica minolta
1st from the front Open the door and removed all Imaging unit start from the black. 2nd from the left side when your facesing the c450 Open remove the waste box. 3rd from there you will see the transfer belt on both side of it you will see screw just under the transfer belt loose it. Slide the transfer belt toward you.
Jan 08, 2015 | Konica Minolta bizhub C450P Laser Printer
Where is the transfer belt located on a Konica Minolta C25
above the 4 drum units have to remove the 4 toners the 4 image units and the transfer belts is removed from the right side after removing a section of the duplexer on the right side door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 08, 2014 | Konica Minolta Bizhub C25 C35 C35p Color...
P7 p28 p5 c300
For P-7 replace the magenta image unit
for P-5 and P-28 unless you know your way around Konica Minolta Copiers you need to have the two sensor located below the transfer belt on the right side cleaned and or replaced, to clean them you must uncover them because when the belt assy. is remove the are covered.
Mar 21, 2014 | Konica Minolta Bizhub C300 All-In-One...
How to clean transferbelt in bizhub c220
Remove the transfer belt unit,remove the upper cover and used a vacum cleaner,cleaning under transfer belt cleaning belt section.
Jan 26, 2013 | Konica Minolta Bizhub C220 Color Copier
Error C500.
PROBABLE CAUSES:
1. Insufficient airflow during idle causing internal machine temperature to rise. Toner is backing up or solidifying in the cleaning unit box for the transfer belt causing the transfer belt drive motor (M18) to bind.
Replace the Belt Cleaning Unit (p/n 65LA R702 00) and install attached Special Printer Control firmware (version 51-PBF0 for the 8050/CF5001 and version 12-PBF0 for the bizhub PRO C500). This firmware keeps M11 (Transfer Belt Cooling Fan) ON for a period after the copy process has completed which helps keep the internal temperature at normal levels. The firmware can also be download from the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
Note: Firmware version 51-PBF0 is primarily for the 8050, but can be used for the CF5001. When using the ISW tool to download the firmware please select the 8050 from the drop down. If the CF5001 is selected the ISW tool will not see the file.
2. The paper exit fans (M61/M62/M63) DIPswitch is not turned ON.
Set software DIPSW 21-0 = 1 to enable the paper exit fans.
3. Dirty or failed transfer belt drive motor encoder disk sensor assembly.
Clean the transfer belt drive motor encoder disk and sensors. Replace the assembly (p/n 65AA -909 1E) as necessary.
4. Failed M18 transfer belt drive motor.
Replace M18 transfer belt drive motor (p/n 26WA 8001 3).
Jan 18, 2011 | Office Equipment & Supplies
WHERE IS THE TRANSFER UNIT LOCATED ON KONICA
Unit is in the right side cover. New one should have instructions with it, but I think you unlock a handle and swap, then lock handle again.
Apr 06, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Oct 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
604 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
