Question about Vehicle Parts & Accessories
Need install manual 4 ezsdei7701 clifford car alarm
I just got a clifford car alarm (ezsdei7701)but i need the installation manual can you help
alicantecoli
  • 22382 Answers
SOURCE: spy car alarm manual
forget the boy racer add on they are useless,if i want to pinch it it will take me minutes to silence and by-pass it ......buy a steering lock that fits over the steering wheel complete so air bag cant be half inched either and never leave anything in car worth nicking ,these sort of things take too long to remove,and if you put car into a garage for servicing never leave the key for steering lock with the car keys .Another and cheaper way is to put a switch in power cable to the fuel pump and place switch where only you know where it is behind facia or seat .now that slows them down.Best way to half inch a car is to pick it up with a breakdown truck .no body bats an eyelid
Posted on Nov 22, 2008
insanegtp
  • 112 Answers
SOURCE: Car Alarm
Key on, push the button, if that doesn't work, please post with model #, you can find that by looking under dash and finding system...
Posted on Jan 24, 2009
jmgldsmth
  • 2005 Answers
SOURCE: need instalation manual
http://www.directeddealers.com/manuals/OG/Viper/G3901V_09-2007_web.pdf
Posted on May 03, 2009
SOURCE: clifford concept 300 alarm
i just bought a concept 300 but have no dirgram can you point me were i can get one
Posted on Jun 05, 2009
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
Key immobiliser ignition switch
Most audio mobile mechanics are trained in installing alarms as well as other things on cars part and present. It would be worth finding one and enquiring about your alarm. When you phoned Clifford I am guessing that you spoke to the receptionist and they just looked it up on their computer as the model is not stocked they probably won't help as it most likely wouldn't of had any warranty anyway. I had a 97 corolla and it had a stock alarm on it and it was good. Good luck anyway. If you are not confident enough don't touch as electrics are tricky on cars specially when taking advice that is noteface to face at the problem.
Sep 14, 2013 | 1997 Toyota Corolla
Clifford alarm
check the internal battery of the alarm as it may be getting low on charge.
May 30, 2013 | Vehicle Parts & Accessories
I need a Clifford 50.7x installation manual
go to www. fitnessmanualsonline.com and download for freeGod bless youcreateLink
Dec 14, 2012 | Clifford Matrix 50.7X - Car Alarm with...
Battery went dead,clifford alarm locked the engine
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Looking for clifford alarm manual,did not use the car for 8 months,the sound on the alarm went,does work ,lock unlock but no sound ,maybe easy repair????any ideea?thx
look in the phone book, (YES) the phone book and see if there's an alarm dealer around you that is an authorized dealer for clifford they should be able to assist you.
Sep 20, 2009 | Car Audio & Video
Loss of Installation Instructions for Daewoo plasma TV
You can get an owner manual at e-daewoo.com but you dont need it to install it, in fact it is pretty easy and if you need help to do that I can guide you to install it
May 13, 2009 | Televison & Video
Clifford wont cherp
refer to the owners manual your LCD screen should have a menu/setting/etc. type of thing to help set back the chirp..
Jun 24, 2008 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
295 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
