Question about Sony Playstation 3 (PS3) Console
The TV screen goes intermittently blank when the PS3 is turned on. Gameplay is affected.Even when using any of the other PS3 service the blank screen problems occur. Recently is has been occuring more regularly. How to fix?
  • 48 Answers
It seems the system its self is stronger than the tv componets try using an a game surge protector they usually work
Posted on Dec 11, 2009
SCreen goes blank intermittendtly
It is OK that there is enough space where your PS3 is located but what is required is ventilation to take out the heat which may be the case in this case. Therefore try to put PS3 in a place where the place gets enough ventilation. There is no other reason for screen going blank intermittently Also, it is suggested that you clean the terminals of the cables periodically by disconnecting them as the heat attracts dust and the contacts become dirty with dust thus affecting the connections
Apr 12, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My kids PS3 comes on and then when you push play the light turns green and you hear it start up for a couple of seconds and then it goes off.
R - Restore: Restore default settings E - Environment: Change your environment, remove from media cabinet, try different media, try different equipment (TV, router, hotspot, etc.). P - Power Cycle: Power cycle by unplugging your networking equipment from wall for 2 minutes to reset. A - Access this Knowledge Center for useful articles to resolve issues. I - Install the latest System Software Update. R - Resolved: In most cases these steps can resolve your issue.
Adjust the video input on the TV to match the input connector that is being used to connect to the PS3™ system. Check that the cable is securely inserted. Try disconnecting the cable from the PS3™ system or TV and then reconnecting it. There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3™ system. If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system’s power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution. If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system’s video output settings, and then select all the resolutions that are supported by the TV.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
When my ps3 is hooked up to my proscan lcd 37LC30S60 via hdmi it has a blank screen that says no support
Have you tried changing the settings on the ps3? If you go into the display settings adjust them Also if you want to change the ps3 to the default
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn the system off.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps.
    Thank you,
    Lee
    Dec 12, 2009 | Proscan 37LC30S60 TV
    Ps3 turns on with green light an doesn't show users screen blank
    Your tv screen has problems with the video mode
    that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
    Succes.
    Sep 03, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 as no video or sound i bought 3 wires for the tv and no color or soud sows we even used a ps2 cable
    Excerpt from the PlayStation 3 Manual:
    There is no picture on the TV screen.
    *Check that the input mode of the TV is appropriate for the connector in use on the system.
    *There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3 system.
    *If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
    *If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
    Jul 29, 2009 | Sony Playstation 3 (PS3) Console
    TV Blank when powering PS3
    When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
    Apr 20, 2009 | Sony Playstation 3 (PS3) Console
    Video goes Balck with some games
    Hi
    Offhand, have you tried another souce for the video or connecting the ps3 another way to the television?
    Is your ps3 covered by warranty, this seems like a possible hardware problem. But first have you tried updating your ps3 internal software to the latest available?
    http://www.us.playstation.com/Support/SystemUpdates/PS3
    Please check these things first and let mek now.
    Mar 15, 2009 | Sony Playstation 3 (PS3) Console
    Code displayed over my ps3 xmb, affects gameplay
    video rsx cpu maybe partially damaged..i can probably fix it.
    Nov 10, 2008 | Sony Playstation 3 (PS3) Console
    Problem connecting HDMI cable
    Hey there I don't see why your playstation 3 should be doing that other than the console being defective. Sony doesn't have this problem that often and actually this is the first time i have heard of such problem. Try making sure the the HDMI cable is connected at both ends all the way in and also make sure your Samsung is a 1080P which i am pretty sure it is and finally if you have a friend or another 1080P HDTV in your house i would try and see if your ps3 will support the 1080P feature. If you still have the problem even when you use a different TV then its the ps3 that is malfunctioning otherwise it would be your Samsung. Let me know how that turns out alright.
    Oct 04, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    239 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
