Dell monitor E196FPF when computor turns off monitor stays on screen keeps changing colours,have to turn main power supply any ideas please.regards phil
  • 591 Answers
This sounds like a "Screen Saver" in the monitor ... go in to the monitor's Setup and disable the screen saver.
Posted on Dec 10, 2009
Change the settings on the monitor
I guess you don't see anything wrong when the pc is running. Turning the computer off alos turns the monitor off .
Turn on the monitor by itself and see if you any colors besides black with a message or without it.
Sep 12, 2014 | Dell Computers & Internet
Dell 19" LCD E196FPf monitor
Yes,
http://s807.photobucket.com/albums/yy352/budm/Dell%20%20E196FP%20Rev%20A03/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Feb 26, 2011 | Dell E196FP 19" LCD Monitor
My monitor doesn't want to stay on when I first turn my computor on in the morning. The screen keeps going black after a few seconds. I have to keep turning it off and back on several times before the...
That is a sign of dying power supply due to bad cDC filter caps.
Please read my guide and look at the album of bad caps so you will know what to look for.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 31, 2010 | Gateway FPD1975W 19" LCD Monitor
The monitor keeps going into auto power save and remains black. Have turned off and on, unplugged, waited and plugged back in. Have unplugged from computor and plugged back in. Will not get off of power...
It more likely went into shutdown, but try it on another PC first, if it still does not work, then read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 04, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor keeps turning off but power says it's still on
You are OK with the power cord, more likely to be failure in the power supply/Inverter board, look for bad fuse and shorterd transistors, see Dell pictures here: http://s807.photobucket.com/home/budm/allalbums
Transistors should be checked out off circuits.
Mar 16, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
When I start my computer my Dell S199WFP Flat Panel Monitor does not go on and stay on. It comes on for about two seconds or and switches off. I have to turn it on about 20-30 before it will stay on. While...
Hello
You have capacitors on the monitors power supply that have changed value. Soon they will keep the monitor from turning on at all. Send it to a company like mine or take it to a local repair person.
Aug 02, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
AS501 Monitor Problem
Your monitor have a bad condensatorin the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive) or if you have electronic tools, found and replace that condensator.(cheaper way...)
Best Regards!
Jun 24, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Won't turn on
This is a problem with either the power supply or or logic circuit. It could also be caused by a failure in the back light circuits. One of these problems has caused the power supply to go into protection mode and will not turn on due to bad voltages sensed in the feedback circuits. Return to dealer for service. Hope this helps you .
Dec 26, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Computers & Internet Logo
76 people viewed this question
Alun Cox
David Payne
David Payne
