Question about Vehicle Parts & Accessories
1996 lincoln towncar the shift lever has a hard time going into park.
  • 112 Answers
Check your shifter linkage it sounds like it might be bent
Posted on Dec 10, 2009
My 1999 lincoln Continental wont shift out of "PARK"
Is the vehicle parked on an incline? The parking pin may be slightly jammed. If you can VERY CAREFULLY nudge the vehicle up the hill an inch or two, using another vehicle, the shift lever may free itself.
If the vehicle is parked on level ground, suspect the LOCKING SOLENOID for the shift lever.
Less likely, the parking pin may be jammed (inside the transmission), or the shift lever linkage may have become damaged.
Aug 12, 2014 | 1999 Lincoln Continental
2003 aviator won't go into gear
When you say the vehicle "won't go into gear," do you mean you cannot move the lever out of PARK, or do you mean that when you move the lever out of PARK the transmission will not engage?
If the lever will not move out of PARK, check your BRAKE LIGHT fuse, your BRAKE LIGHT switch, and the SOLENOID at the shift mechanism.
If your lever moves out of PARK easily (too easily), it is possible that your shift linkage has broken or come loose.
If your lever moves out of PARK normally but the transmission does not engage, it's time to have the car towed to the transmission repair shop.
Jul 28, 2014 | 2003 Lincoln Aviator
What fuse on 1998 Lincoln Towncar controls breaks and gear
Since you only mentioned drive, I'm going to presume you meant you can't shift into any gear, Is this correct? Normally, I would say this isn't an electrical issue, it's mechanical, either something in the shift column or the shift linkage is broken or come loose so I browsed the fuses in my owner's manual and you can check these fuses: fuse #8 (10A) - Shift Lock, Speed Control, fuse #14 (7.5A) - Transmission Control Switch, fuse #10 (20A) - Brake Pedal Position, Brake Pressure Switch. If you can't shift out of Park, turn key just enough to unlock steering wheel (not turn on dash lights) and see if shift lever moves. If so, then shift into Neutral and start car.
Jun 18, 2014 | 1998 Lincoln Town Car
My 1994 licoln towncar will not go into p[ark
There is an adjustment screw on the linkage connecting the arm from the steering column to the transmission. loosen it, then slide under the car and push the lever on the side of the transmission into park thenpush the shift lever into park then tighten the screw.
Mar 20, 2014 | 1994 Lincoln Town Car
1992 lincoln towncar will not shift out of park (gear)
Check that the brake switch is working or is adjusted right so that when you push on the brake pedal, the car can shift out of park.
Sep 23, 2010 | 1992 Lincoln Town Car
My car won't start unless i move the shift back and forth
There is a safety switch that is made when the shift lever is in Park. When there is play in the lever it won't make the switch. Follow the linkage of the lever to where you find the switch. There will be a way to adjust the play out of it.
Jun 20, 2010 | 1996 Lincoln Town Car
Car wont go in gear
you have a problem with posibly witht he adjustment on you neutral switch. the transmission has this to prevent starting in gear. it obviosly works fine in newtral so it needs to be adjusted or the lever on your transmission needs adjust ment to allow this sensor to do its job
i hope this helps
May 06, 2009 | 1994 Lincoln Town Car
Can't get 1993 Linclon Towncar out of park
SHIFTER LOCKED IN PLACE
  1. Remove the instrument panel cover below the steering column, then remove the steering column shrouds to gain access to the brake transmission shift interlock (BTSI) solenoid. The solenoid is part of the interlock cable assembly.
  2. Disconnect the wire connector from the rear of the BTSI solenoid.
  3. Insert the ignition key and turn it to the ON position.
  4. With the brakes applied, try moving the shifter out of the PARK position.
    • If the lever now moves freely in and out of PARK, perform the Circuit Test below.
    • If the shift lever still does not move from the PARK position, remove the BTSI solenoid from the shift lever assembly. If the shift lever now moves freely in and out of the park position, the BTSI solenoid is faulty and the interlock cable must be replaced. If the shift lever still does not move from the park position, the problem is in the shift lever assembly or the ignition interlock cassette
Feb 21, 2009 | 1993 Lincoln Town Car
1996 licoln towncar gear selector
MY LINCOLN WOULDN'T GO INTO ANY GEAR.I WAS STRANDED I CALLED THE FORD PLACE,THEY SAID ON THE BRAKE PEDAL UPWARD THERES A LEVER.A CHILD SAFTY THING.THEY SAID PUSH UP ON IT I DID AND IT WORKED.IT HAPPEN AGAIN BEFORE WE GOT IT FIXED,AND I PUSHES ON IT AND IT WORKED.MY HUSBAND REPLACED IT FOR AROUND 10 DOLLARS.HOPE THIS HELPS
Sep 22, 2008 | 1996 Lincoln Town Car
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
