Question about HP Pavilion zd8000 Notebook
Randomly Shuts Off
My laptop is plugged in and it seems the AC power is fully functional. The most frequent times that it shuts off are when there is a CD inserted in the computer, or I am playing an online game, such as Guild Wars. I have no clue why this happens, and it is very frustrating. I am even using a Targus cooling unit, set under my laptop. Someone please help!
  • 3 more comments
  • Zandri Jan 20, 2008
    I think the cooling unit is working pretty well. It doesnt seem to be that hot when it shuts off, i havent been paying that much attention. Before my brother handed the computer over to me, he had cleaned all the fans, nooks, and crannies with an air duster. Sometimes the AC battery pack thing gets really hot though. Also, the spot right beside the touchpad gets really warm. But when I notice that, it never shuts off. It is still running, it seems to only shut off at varying times.
  • Zandri Jan 23, 2008
    Sounds wonderful, I will try it sometime...I will let you know the outcome, and thanks in advance!
  • Zandri Apr 25, 2008
    I have figured out the problem. I need a new AC power cord because the battery is shot, and the current power cord I have is faulty. Whenever the AC shorts out for a split second, the laptop has no way to stay on, and just shuts off.
    Thanks so much for your help!
  • Anonymous May 24, 2008
    My laptop is shutting down while I am working on it, and I'm not sure why. I no longer have the warranty on it and I'm not sure where I should take it to get it looked at!??
  • Debbie7 May 30, 2008
    I have the same problem, my laptop shuts down periodically as well. Sometimes it doesn't even seem to be hot or even warm. This last time it shut down (last night), I couldn't get it started again today. I took the battery out and put it back in, that didn't work. I unplugged it from the main source and took the battery out, that didn't work. I don't know what to do. (The battery is only 2 weeks old.)
Hi zandri,
I had the random shut off problem a few times with my zd8000. It turned out that the cooling vents were blocked and the processor was overheating. It has safty circuts to shut itself off when it gets too hot.
Even if you use a cool pad it won't help if the processor can't get the air.
I solved this problem by using a shop-vac (5 hp) to pull the blockage back out through the fans. It turned out that a good protion of our long haired cat had made it's way into the machine. I sucked out enough fur to cover a small kitten. :D
HP assured me the ports couldn't be blocked but in reality it was a different story. Now I clean the cooling ports every three months or so and every time I get more debri.
The zd8000 is a heat monster anyway. You need to keep it cool. Suck out every opening in the case (with power off!). I stir the fans with the sucktion until they get spinning so it keeps the fuzz off them too.
I've been fine since I started the vacuuming. Hope it helps.
Posted on Jan 20, 2008
Is it hot ?
if it is, it is overheating, try to clean the cpu fan.
Posted on Jan 19, 2008
6ya staff
SOURCE:
Acer aspire switch 10 e, keeps shutting off randomly even when ac charger is being used
Is the airway clear to allow for good cooling? Bad connection on the RAM or HDD socket?
Aug 28, 2016 | Acer Aspire Computers & Internet
My computer shuts down when i plug in the charger
Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Power is erratic. Shuts off randomly.
it could be caused by a lot of things. isolate it first. since its randomly shutting down, try first in normal mode. does it heats up before it turns off, if yes its an overheating issue. you may need to replace fan or even motherboard of your pc. have you checked your battery? is it properly seated? or is the problem happening when your system is plugged with the ac adapter? try to check the power cable.
Apr 06, 2010 | Sony VAIO VGN-T350P/T Notebook
Randomly shuts off and takes many times to try to
Take out the battery and only have the ac adapter hooked up. If you can get it to turn on the first try then that means the battery is shorting out the motherboard.
If you do this and your still having power problems then that means the motherboard is starting to go bad on you and the motherboard would have to be replaced.
Jan 23, 2010 | HP Pavilion dv1000 Notebook
My Averatec 3200 turns of randomly...
Check the CPU and Fan/Heatsink assembly. I have a pretty good feeling that the CPU is heating up too much and is not being cooled properly. There may be lint or dust clogged in the fan. You can get access to this pretty easy by removing a few screws on the bottom panel that houses the CPU/fan.
Feb 20, 2009 | Averatec 3200 Notebook
Randomly Shuts Off
I think ur laptop goes to power saving mode.Right click on the desktop then choose personalize or properties if u have xp.
Then click on screen saver at the bottom click change power settings.Now if the power saver is checked then uncheck it and choose balanced in that change the timings as when it should sleep according to ur wish.
If u have any other problems please ask me..
Goodluck
Please don't forget to rate me as fixya..
Feb 06, 2008 | HP Pavilion zd8000 Notebook
Laptop shutting off
This problem has happened to me on several occasions. I found that the connector that you plug your power supply into on the motherboard gets loose. Not making a good connection and like you said needs to be re soldered. Before attempting this, stick a small screwdriver in there and see if it's loose. If it is, then EVERYTHING needs to come off to get to it. Not a quick project. I suggest you take pictures along the way just in case. Good luck!
Nov 13, 2006 | Toshiba Satellite M35X-S149 Notebook
HP Pavilion zd8000 Notebook Logo
161 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
