Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
Anonymous Posted on Dec 10, 2009
When i turn on my tv it gets fuzz like lines and it will eather get a little better or ust go all fuzzy
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
75
Points
I beat it with a big ******* hammer!!!!!!!!!!!!!piece of
TV has been getting static fuzzy lines, like snow in the picture increasingly bad. Now makes a pop noise, goes black for 2 seconds and comes back on. Thank you
Time ofr a new tv. The guns or gun control system is goign bad. Before it results in something worse ust replace the unit. Cost of repair is not worth the price.
My samsung flatscreen picture is starting to look really fuzzie in some areas on the screen it is almost like a picture on top of a picture.
fuzz balls in some areas on plasmas can actually be adjusted out on the Y board first mark the controls with a sharpy then watch the fuzz spot as you turn the controls a little to see which one clears up the picture. the back needs to be off and the Y board is laft side when you are facing the back
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
2answers
My Vizio 42in. is really fuzzy
If the picture is clear when using a DVD and remains "fuzzy" only with cable, then either the cable is bad or the up-conmvert from standard def to Hidef is creating the "fuzz". Depending upon the method used by the set to perform the "up-convert", the noise you are seeing may be normal.
Dan
TV does receive broadcast signal
get some rabbit ears..... or a little dish reciever that sits ontop of ur tv til FEB 17th...then u have to have the new converter, which u can get government coupons online ....or ull just get fuzz after that... i use the old cheap rabbit ears antennae and i get 6 channels ....
1helpful
RCA Big Screen is fuzzy.
Common problem and RCA recommends the following to cure: replace R17520 with p/n# 218508, C11503 with p/n# 194903, and crystal.
Bill
2answers
Sanyo 27" Problem: Fuzzy Screen
sanyo does this alot it is either you need to replace your tuner or you have two resistors 220k ohm s that need to be replaced.this will fix your problem.if repair cost is cheaper to fix then buy a new one its up to on that one!
Red lines and burn in
Hi: Did you get yours fixed? If not whould like to work a deal to buy it I figure if I can get 4 or 5 sets I can make one good one out of them!
Fuzzy Screen
you have a defective control module
2answers
Weird error?
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
