Question about Garden
I need to replace all the fuel lines that have broken on a silvereagle saw model number se2016s
  • 376 Answers
SOURCE: won't start
The cable is part of the ignition coil. The 'bare' wire you saw is the spark plug terminal that has a right angle bend in the end that sticks into the cable. You pulled it out trying to remove the cable off the plug, Those kind of connectors fit tightly and it is better to pry up on the bottom of the boot when removing plug wire. Pull the coiled wire connector off the plug, slide the boot back and with pair of pliers, squeeze the connector back into the cable, in a different spot. Slide the boot back and put it back on the plug.
Posted on May 22, 2009
  • 61 Answers
SOURCE: Homelite xl-175 chain saw no prime
As long as the line fits tight so its not sucking air you should be ok.. try changing out the plug if its old. Clean out the air filter too.. But the line should be ok as long as its tight..
Posted on Jul 10, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Posted on Oct 24, 2009
SOURCE: I have a Husqvarna model 444 chain saw. The fuel
order new fuel line and filter from www.randysenginerepair.biz
remove top cover, remove air filter, remove fuel line from carburetor, empty gas tank, pull remains of fuel line out of tank and replace with new.
Posted on Nov 06, 2010
puertobori
  • 7733 Answers
SOURCE: I need to replace the
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 22, 2010
My Husky Chain 18 in saw wont start after replacing fuel line
I have seen the current gas eat away and melt fuel lines. I would bet there is some gunk in the carb which is why you are not seeing fuel on the plug. You will need to remove, disassemble, and clean the carb. If you haven't done it already make sure you replace the fuel filter too.
May 19, 2012 | Husqvarna Garden
Trying to get a fuel diagram for silvereagle
you might find something at a dealer like www.arcolawn.com. most carburetor brands have lookups and diagrams on their sites allowing you to view by carburetor model.
For example walbro carburetor wt256 typed into the search will pull up all the parts for that carburetor.
Look for the numbers and brand on the side of the carburetor and you will be set.
Good luck Joe
Feb 12, 2011 | McCulloch Garden
I am repairing a SE2016s 2.0 model 322764-00, and have a broken fuel line going to the primer. There are 2 lines going to the primer, and I fail to see where the line was connected.
Both lines go back in the fuel tank. There should be two holes right next to each other that the lines go through and they should be fairly snug fitting on the lines to prevent gas from leaking out.
Sep 09, 2010 | McCulloch Garden
Saw is a 14 inch model 1950. Saw starts but won't run
Check the fuel filter, air filter and muffler for plugging. Make sure the carburetor fasteners are tight. Does the primer bulb fill with fuel after several pumps? Hope this helps!
May 12, 2010 | Poulan 14" Chainsaw
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
Fuel line diagram model 2450
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly (a "2450 Gas Saw Type 7" example IPL follows. may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2450-Gas-Saw-Type-7/75.2450-Gas-Saw-Type-7.1.59.1.html
Poulan.com (All models)
The dash number of your serial number is the type.
The Poulan print is deceptive, my schematic (below) is correct.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Garden
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Echo 452VL chainsaw won't start
yes it does.the filter is in the fuel tank on the end of fuel line.if it isn't the fuel line needs to be replaced and a new filter installed.there is most likely some of the fuel line in side the carb. there is a small filter inside and it usualy collects the broken fuel line there. take the carb apart oppiset of the diaphram.usualy it's the side with only one screw.carefully blow the **** from it and the saw will get fuel again and start
Feb 23, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Broken Gas Line
You can obtain a length of gas line locally. Just take the broken piece to any store that services trimmers and chain saws. They will be able to match it.
Dec 06, 2008 | Husqvarna Forest & Garden 125l 18" Gas...
Loose Fuel Line In the Gas Tank
hi rhopdo
try to find the spark plug near the muffler(exhaust)
check where is the hole from the gas tank, connect the fuel line to the carb.
yours savumihai71
Dec 01, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
108 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
