Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Electrolux 2100 canister vacuum
My vacuum was working fine and I changed the bag, now when I try to connect the hose to the canister to run it again, it immediately stops. When I disconnect the hose, it runs fine without the hose. There are not any obstructions in the hose that I can find. I ran something all the way through the hose and nothing came out. When I blow air in one end of the hose, I can feel the air coming out the other end. Help!!!
  • rickbigdog Feb 04, 2008
    My electrolux keeps shutting off and indicating a full bag situation even tho I put in clean bag. shuts off when I place my hand in front of intake. Can someone help?
  • 75 Answers
Possibly the bag sensor is bad.
Posted on Jan 21, 2008
  • 397 Answers
Check the hose by putting a penny in one end and see if it comes out the other, you might have a possible clog, lux canisters are designed with a fail safe
Posted on Jan 20, 2008
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
2100 comes on but will not keep running, I have changed filter and bag.
The dial on top of the machine should be set about mid-point. If it is, then turn until the small dot and the arrow are lined up. If this doesn't help, turn all the way around so large dot and arrow line up.
2. Detach hose from vacuum. Turn on. If it continues running, place hand flat against the intake. If it shuts off immediately, there's probably a problem with the "Control Valve Assembly". This is a part that can be purchased at your local Aerus Electrolux store. I highly recommend allowing them to replace it rather than trying to yourself.
If you don't know where the closest store is, go to aerusonline.com, click on "store locator" button at bottom of page, type in your zip code and click on the find store button.
If your vacuum runs fine without the hose attached, then check hose and power nozzle for a clog.
Sep 30, 2010 | Electrolux C101 Bagged Canister Vacuum
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Dec 16, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 | Vacuums
Vacuum just stopped working.
is there a filter in it if so clean the filter.try it without the bag in it.make sure the bag is in correctly.does the bag expand when you turn it on.you might have something caught up in the hose.take the hose off and blow througfh it.if you can't its clogged.also check the inlet where the dirt goes into the bag.the inlet might be clogged.please leave feedback
May 04, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Protection light on my Electrolux 2100 vac is on
the carpet attachment pushes on a smsll switch to turn on the vac look for the pin
Apr 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
693 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
