Question about HP 2500 CM InkJet Printer
HP 2500CM displays mech carriage jam 415 msg after power on. There is no jam, encoder strip replaced, PCA connectors and ribbon cable okay.
I cleaned the 4 printerheads and still the display says:replace the printerheads,is there asolution?
Posted on Mar 19, 2010
  • 231 Answers
Is the carriage rail clean, and lightly lubricated?
Cheat the door switch and observe the carriage moving at boot up.
(Keep your fingers out of the way!)
See if you can spot where it sticks.
Sometimes the printhead capping unit / service station seizes up, and the carriage cannot leave / return to the home position.
This model was not one of their best.... Good luck
Posted on Dec 10, 2009
  • Bo Herrmannsen
    Bo Herrmannsen Oct 31, 2013
    have same problem... it does not stick, but it slams carriage against end stop at far right...
Persistent Error 86:01
Oh my throw it away, too much you have tinkered with its not worth the headache
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
Error code 02.01.10
02.1:10 error indicates that the encoder is not working.
Try the following:
Switch power off and unplug the power cord. Reconnect and turn the power back on.
Check that the trailing cable is not damaged (wide cable that goes from the main PCA to the Carriage PCA)
Replace parts in this order: Trailing Cable, Carriage PCA, Main PCA.
Aug 14, 2013 | HP Designjet T610 InkJet Printer
Clarify: #Error appearing immediately with sudden ****? or while carriage parking in serve station area?# remove & take out service station, place it out side(to avoid capping/wiping by cleaners)..check
# check carriage bushing warn out condition( too much play of carriage causes this error)
# trailing cable flexibility good? or its obstructing the carriage path?
# take out cutter assembly from rail.. check..
# Check carriage belt tension, adjust if required.
# Check carriage belt properly installed? re-install again
Best of luck....
Jul 24, 2012 | HP Designjet Z6100 InkJet Printer
I have a hp 6100 series printer. I can not print. I get a message. Open door. Clear carriage jam and then press Enter. I do not see any jams.
Hi sir!
Could you inspect your printer for me and see if there is a long clear plastic that fell inside the rollers. This is called the Encoder Strip. This plastic strip is very important inside the printer. The carriage determines its position from the tiny lines on this encoder strip.
This plastic should be in its proper place, goes through the slot in the carriage, the other end of this is attached on a spring hook on the left and a stationary hook on the right. Hook It Back!! That will fix it.
Sometimes, these Clear Carriage Jam issues is brought about by hardware problem. And the best DiY solution for this is to reset the printer. Follow these steps before performing the reset procedure.
I hope this will work for you if my first solution did not work.
1. Unplug the power cable from the back of the printer (The other end of the plug should be directly connected to wall outlet)
2. Keep on tapping the Power button on the printer for 30 seconds, then plug in back the power cable at the back of the printer.
3. (Make sure no jam in the carriage) Open the carriage door and take out the cartridges, clean the cartridges with a dry cloth.
4. Make sure the power is turned on and gently move the carriage (Catridge holder) and check if anything is jamming it.
To reset the printer
1. Unplug the power cable from the back of the computer
2. Press and hold down the (#) and the (6) button at the same time, then plug in back the power cable
3. Release the (#) and (6) button (the printer may shut down) on the screen it will display SEMI NVM reset
(If none of them happens try it once more)
Another reset
2. Press and hold down the (#) and the (9) button at the same time, then plug in back the power cable
3. Release the (#) and (9) button (the printer may shut down) on the screen it will display SEMI NVM reset
If the problems still persist, You can call HP to return the printer and get an upgrade at low price for replacing the damage printer. hp no.: 1-800-474-6836
Please rate if this solution find its way to solve your problem.
Thank you for using Fixya.
Sep 20, 2010 | Computers & Internet
Carriage jam open door carriage jam and then press OK to continue
You would be absolutely amazed how small a piece of debris can cause that fault. Use a flashlight and look carefully for any piece of debris and remove it.
Get some "canned air" from any computer or office supply store and blow out the interior of the printer thoroughly.
Nov 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 6110 Printer jams after 1 sheet
Thanks for contacting Fixya.com
Please try the bellow mentioned troubleshooting steps to help elliminate the paper jam and noise issue for your printer:
Things that cause a carriage jam error:
Dirty encoder strip.
Damaged encoder strip.
Encoder strip spring mount out of position so strip is slack.
Encoder strip not threaded through the emitter/detector that reads the lines on the strip. (just fixed a 5550 with this problem)
Emitter/detector that reads the lines on the strip is bad, this is part of the carriage PCA, (board).
Carriage stuck on side because service station is not releasing it.
Carriage stuck due to being tilted at wrong angle, if it's stuck a few inches from the right it needs to move farther to the right to be released, stuck a few inches from the left end move it farther to the left. (instructions probably on HP web site, they are there for the DeskJet 5550)
Carriage binding on rail due to ink build-up or lack of lubrication, (be careful what you use to lube).
Bad carriage motor.
Bad carriage drive belt.
Some machines have a timing disc on the service station motor and may indicate a carriage jam if the service station motor does not turn.
The cause could also be a loose cable connection on a small circuitboard inside the printer (The one that controlled the paper jam sensors) I fixed it by saudering the leads to the board until I had a good connection again.
Thank You and best of luck,.
Jul 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Encoder strip for HP 2175 xi
Here's the solution for fixing a carriage jam on your PSC 2315xi printer. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042632&cc=us&lc=en&dlc=en&product=90812 But, you said the encoder strip came off. I always understood that if the encoder strip came off, the printer was dead. I've never tried to take the encoder strip off and put it back on again to see what happens. The encoder strip is what tells the carriage where it is. Without the encoder strip, the carriage doesn't know where to go.
Jun 09, 2009 | HP Office Equipment & Supplies
HP Photosmart c5280
Make sure to check all the way to the right and left inside. I ussually find paper loose in either of those ends. Then check your encoder strip which is the plastic strip that the carriage slides on. This may be dirty causing this issue. Use a soft paper towel and alcohol. Windex is okay to but may leave streaks on it and give same issue.
Dec 09, 2008 | HP Photosmart C5280 InkJet Printer
HP 1000C inkjet
plastic ribbon is "encoder strip"
encoder strip fitted in carriage block unit
Feb 05, 2008 | HP DeskJet 1000cxi InkJet Printer
HP 2500 CM InkJet Printer Logo
202 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
