Question about Nintendo Wii Console
Its locked up on the page that reads press "A" to continue, it will not read....from my remote(s)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Might be a problem with the System or the wii, if you just bought it take it back to the store and tell them the problem to get a new console.
If that did not help contact Nintendo.
Posted on Dec 10, 2009
I have a f10500pvr and i'm getting no signal. Every time I press the remote, a lock symbol flashes red. Have I locked myself out? Is there a way of unlocking?
that is not a hard drive, you posted to HDD,
PVR
read the manual, all that is in the manual
go to the makers page, and RTM.
Oct 02, 2013 | Computers & Internet
Sharp Aquos RC Control Lock and Operation Lock Out
When all else fails read the owners manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
Apr 05, 2012 | Televison & Video
Unlocking the remote and panel for Sharp Aquos LC-46LE832U 46 in. HDTV LCD TELEVISION
When all else fails read the owner manual page 35:
then press INPUT.
Out".
Took 5 minutes to find the manual for this unit. GOOGLE
Apr 05, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I just replaced my ink on E238 laser printer and the yellow light is flashing. I have been on hold for 45 mins with you help line. Everything still prints but the light is flashing
  1. Enter the printer's Configuration Menu. To do this:
  2. Turn off the printer.
  3. Open the front cover
  4. Press and hold the Continue () button.
  5. With the front cover open and the Continue button pressed down, power on the printer.
  6. Hold the Continue button until all the lights cycle.
  7. When just the Error light (!) is displayed, close the front cover. The top four lights of the operator panel should come on, indicating that the printer is in configuration mode.
  8. Print the Configuration Settings page. To do this:
    • Press and hold the Continue () button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the non·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
      Save this page for possible later use.
  9. Reset the photoconductor page count as follows:
  10. Press and release the Cancel button () to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low () light is the only light left on.
  12. Press and hold the Continue button until all of the lights flash.
  13. Then release the button. When the Toner Low light is once again the only light left on, the photoconductor page count should be reset to zero.
  14. Return the printer to normal mode. To do this:
    • Power it off for five seconds and then turn it back on.
  15. Print a menu settings page. To do this:
    • When the Ready () light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
  16. Check the photoconductor reading on the menu settings page. To do this:
  17. Look for a section labeled Cartridge Information and locate the word Photoconductor under that heading.
  18. Confirm that the photoconductor level reading is OK or close to 100%.
  19. If the photoconductor reading is low, try printing 10 - 20 pages.
  20. Print the menu settings page(s) again. Confirm that the photoconductor level reading is OK or close to 100%.
  21. If the photoconductor reading is still low, refer to the Configuration Settings page you printed in Step 2.
  22. Confirm that Reset Photoconductor Counter is listed on the page.
    Also confirm that the light sequence for the photoconductor counter is the Toner Low light.
    • If the light sequence is correct, try repeating this entire procedure again from the beginning to reset the counter once more.
    • If a different light sequence is listed for the photoconductor counter, repeat the procedure but this time, instead of stopping at the Toner Low light (Step 3.2), press the Cancel button until the operator panel shows the light sequence that corresponds to the one listed on the Configuration Settings page. Continue with the remainder of the procedure as before to reset the counter again.
  23. If the photoconductor reading is still low after the page reset procedure has been performed twice, the printer may require service.
May 04, 2011 | Lexmark E238 Laser Printer
1997 camry remot key
Try this.
key not in ignition.
driver door open-others closed
driver door unlocked
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice
this is rewrite mode,have all remotes to reprogram
it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possesion,you are done.
to end mode open door or insert key into ig.you can do up to 4 remotes.read this a couple of times to get the sequence down.there are time restraints,but if you go in order it will work.do not wait more than a second b/t each step and you will be ok.i know from experience that you can do this as fast as you can and it will enter mode.if steps out of order or you wait to long it wont.print this and have in lap,read ahead of what you are doing.good luck.
Jun 10, 2009 | 2001 Toyota Camry
Dmr-e55 disc will not eject
Try pressing and holding ENTER and RETURN on the remote simultaneously and see if that clears the problem.
Apr 12, 2009 | Panasonic DMR-E55 DVD Recorder
I have just bought a new photoconducter unit and put it in the printer. Instructions talk about select, return buttons, menu buttons and exit buttons. My printer does not seem to have this. It only has the...
  3. Open the front cover, as shown below.
  4. Press and hold the Continue (pattlnk_1122005_1857-enus20682_continuebuttonicon_e230_en_us.gif) button.
    • Press and hold the Continue (pattlnk_1122005_1857-enus20682_continuebuttonicon_e230_en_us.gif) button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the non·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
  10. Press and release the Cancel button (pattlnk_1122005_1917-enus20682_cancelbuttonicon_e230_en_us.gif) to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low (pattlnk_1122005_215-enus20682_tonerlowbuttonicon_e230_en_us.gif) light is the only light left on.
    • When the Ready (pattlnk_1122005_218-enus20682_readylighticon_e230_en_us.gif) light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
Jan 01, 2009 | Lexmark E238 Laser Printer
Viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Dec 21, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Command codes
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
Mar 07, 2008 | Sony RDR-GX355
Nintendo Wii Console Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
