Question about Cuisinart Little Pro Plus LPP 3 Cups Food Processor
The drive shaft extending vertically from the motor base has developed a crack. This runs from the top of the shaft down to almost where the shaft enters the motor base. The effect is to make the diameter of the shaft larger. The blades can still be forced down onto the shaft but are very difficult to remove. It appears that the crack is in a plastic cover to a metal drive shaft. Can this be replaced ? How ? Where can I obtain the part ? Are there directions for replaceing this part ?
I just called Cuisinart customer service. Depending on your model, it sould be under warranty. They sent me a new shaft sheath immediately with no expense.
Posted on Jan 19, 2010
    President:
  • 1,214 Answers
You can possibly get parts for this, but you may find it's more expensive to buy parts, than to just buy a new one.
Try www.SearsPartsDirect.com for a complete exploded view and parts listing, as well as pricing. There may be other sites that offer this as well. You will need the Model and possibly serial number.
I would urge you not to use the unit until it's repaired. What you describe can be very dangerous.
Posted on Dec 09, 2009
How do I remove my cracked support bearing on my Kitchenaid food processor 1333?+
Do you mean the bearing on the motor shaft within that circular plastic ring that moves up and down when moving the slicing thickness lever? If yes then a couple of screwdrivers under it one on each side to lever it up. At the same time it will force the black shaft sleeve up and off the motor shaft.
Oct 13, 2016 | KitchenAid Food Processors
How do I fix my Kitchenaid food processor? Motor hums but center shaft is stuck and won't turn.
Hi Eric, you are going to have to get the motor out and yes it will be because of the spilled liquid fusing/rusting the motor armature shaft into the bronze bush. Those motors are very expensive so worth a go to save it. You will have to get the plastic sleeve off that shaft first before you can get the motor out. Removal will destroy the sleeve. I drill a hole through the top of the sleeve, side to side leaving about 5mm of meat at the top. I shackle a chain through it and attach it to my bench leg and then accelerate the whole motor unit away in a straight line. The shaft needs to be pointing at the attachment point on the bench or it can slip from your hands creating more grief. It will only take 1 to 3 pulls, 1st one doesn't work do it harder, same with second pull and harder for the 3rd. The chain needs to have welded links or the chain will break. That is far the easiest removal method I have found, other methods could involve hacksawing it down one side being careful not to damage the metal shaft or melting a line down 1 side to split it open with a soldering iron. Once that is off then remove base, detach motor wires from pcb and remove the screws under the plastic caps on top of the top housing. Then it will be working away with levers and a spanner on the shaft and CRC, sweat and time. If you strike trouble after that email me
screaming_skull@hotmail.com Cheers Ross
Apr 03, 2015 | KitchenAid KFP600 Ultra Power 11 Cups Food...
The part below the shaft has a crack in it . can it be replaced? this appears to be part of the base . my modle # is wfk600wb.
Yes it is a motor shaft sleeve, it is a normal wear and tear part, try K/A or their service agent closest to you.
Mar 30, 2012 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Cracked plastic sheath on the motor drive shaft
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Im trying to put a belt on a hobart 84146
I'll do my best to recall all the steps, I haven't done it in a while. Read instructions fully before starting, as step three may not be necessary, although if performed you'll have much more room for your hands during the remainder of the process.
1. Lay machine on side/back (so that the knife shaft is standing vertically) to access the bottom.
2. Remove bottom cover panel.
3. Remove motor. Two nuts are easy to access, the other two are quite difficult to reach. This step might not be necessary if only changing a belt because you should be able to slip the old belt off and the new one on without completely removing the knife shaft. If the knife shaft must be removed for some reason, the motor must come out to give you room to fit a puller onto the knife shaft (in order to remove the lower knife shaft bearing and lift out the shaft).
4. Take note of the knife shaft pulley. Notice how close to the casting the pulley is. When re-assembling, you'll need to position the pulley at approximately the same location for the black belt to track properly). Loosen two set screws securing pulley onto knife shaft and slide pulley down (don't lose the key for the pulley when you slide the pully down).
5. On the "outside" of the machine, remove the plastic cover where the knife shaft enters the casting.
6. Now visible is a special locknut and special lockwasher (sorry, don't know their names). One of the tabs of the lockwasher is likely bent upward into one of the slots of the locknut. Use a hammer & punch to bend the tab out of the locknut's slot, allowing the nut to turn.
7. Using a hammer and punch, position the punch in one of the slots on the locknut and spin the nut counter-clockwise with sharp blows with the hammer & punch. Have an assistant hold the shaft to offer some resistance to the shaft spinning if you're having difficulty. This may also be easier with the motor and belts still in position, using the motor to partially hold the shaft from rotating while driving the locknut loose.
8. With the locknut removed, spin it back onto the shaft a few threads with the flat side of the nut towards the casting (upside down compared to it's original, installed position). Don't spin it all the way on, you need room to fit a prybar under the flat edge of the nut.
9. Using two prybars, one directly opposite the other, under the now upside-down locknut, pry up evenly on each side of the locknut, and the shaft usually pops out fairly easily.
10. Back on the bottom side of the machine, slip off the belts and replace with new belts and reassemble machine.
11. Be sure to turn the locknut back around to it's proper orientation and be sure to tighten it with a hammer and punch just as during disassembly (special wrenches exist for those nuts, I don't know their name) and bend one of the lockwasher tabs into one of the locknut slots (even if you need to turn the locknut backwards slightly from it's fully tight position).
When everything is reasembled, be sure the flat black belt tracks properly, that is, make sure it doesn't walk off the pulley as the motor runs (just spin the shaft by hand at first to observe if the belt tracks properly.
Good Luck!
May 15, 2010 | Hobart 84145 Food Processor
How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Mar 11, 2009 | Cuisinart Food Processors
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
How do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Feb 20, 2009 | Food Processors
Robot coupe r 301 ultra
Remove the base the screws are under the rubber feet,on top of the machine there are three screw caps remove these with a bradel, unscrew screws with large torx screw driver, remove spindle anti clockwise by locking out fan at base. for all Robot coupe parts go to http://www.catering-machines.com/
Jun 06, 2008 | Food Processors
Part removal and replacement
The black plastic clutch has a left-handed brass threaded insert. Temporarily remove the motor to hold the shaft and remove the brass insert by rotating clockwise.
Dec 26, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Cuisinart Little Pro Plus LPP 3 Cups Food Processor Logo
357 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Bruce Showalter
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
