Question about Whirlpool Washing Machines
I replaced the pump on my washing machine because it wasnt draining it worked on the first load and then stopped. What else could it be?
    President:
  • 744 Answers
Hi, I am assuming you checked to see if one or both of the clips popped off the pump? if the pump is seated right I would say take it back off and look inside the pump. In all likely hood you will find a sock or something like that in the pump. If this is a front load washer check the filter drain next to the pump. If you have any additional questions please feel free to comment. Mike
Posted on Dec 10, 2009
Not draining
take the bottom panel off and check and clean drain pump filter
Feb 27, 2014 | Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front...
Hi: My samsung washmachine J845 had problems. it wasnt pumping out the water.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 19, 2011 | Washing Machines
Water does not drain, stop working after wash cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 02, 2011 | GE WBSE3120B Top Load Washer
When the cycle gets to drain and spin the washing machine stops working
heatman101
Jan 15, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer isn't draining and spinning. Washer has message coming up- OE and it stops working. We were thinking it was the water pump? Please help.
heatman101
Oct 12, 2010 | LG WM1812C Front Load Washer
It doesnt spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 26, 2010 | KitchenAid KAWS700L Top Load Washer
My whirlpool washer wont drain.
Check the following text to address this issue.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 10, 2009 | Whirlpool Washing Machines
Front loader
wasnt aware its was frontloader, short of blockage of pump, it should drain, ifthe door wasnt locking, it wouldnt fill or wash( fontloader anyway, although you took off the hoses to the pump did you look within the pump for a blockage.(toothpick--- hairpin)
Jan 30, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
