Question about LG LRFD25850 French Door Refrigerator
New refrigerator will not dispense water - LG LRFD25850 French Door Refrigerator
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 161 Answers
Call LG this is covered under your warranty if unit is under 1 yr. old.
Posted on Jan 24, 2010
Frigidaire water dispenser won't work with new filter
The dispenser has a dual water control valves that control ice maker water and dispenser water. To find your parts you will need your refrigerators model number most time found around the fresh food sections door. Below I have a tutorial that may help you determine what may be the problem with dispensing water. Hope this helps, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire Refrigerators
My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Jul 14, 2008 | LG LSC26905TT Side by Side Refrigerator
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
No water from the water dispenser.
a new refrigerator has a water resevoir that has to fill up. you have to hold the water dispenser down for a minute or so to allow this resevoir to fill.
if you have done this already, then you probably have a bad water valve.
Jun 12, 2010 | Whirlpool GS6NBEXR Side by Side...
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
Warm water is coming out of new refrigator water
Is there a coil of tubing inside the refrigerator? This is how they usually cool the water. If you use a lot of water through the dispenser, the water will become warm.
I hope that this helps.
Tim
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Dispenser Temperature not acceptable
This is a brand new refrigerator - I cannot solve the problem and I am returning the refrigerator to the dealer. Thank you, but I am not paying $ to fix a new refrigerator. I have tried everything.
Feb 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool water dispenser
IS THE FRIDGE OMPARTMENT COLD ENOUGH AS THE TANK THAT HOLDS THE WATER IS LOCATED IN THE FRIDGE COMPARTMENT.PLEASE FEEL FREE TO ASK MORE ADVICE.MOHAMED
Jul 07, 2008 | Whirlpool ED2FHEXN Side by Side...
LG LRFD25850 French Door Refrigerator Logo
90 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
