Question about Insignia IS-LCDTV32 32 in. Television
My tv screen is blank the cable box works i can turn the tv on but no picture
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
You can get parts for your TV here:
http://www.shopjimmy.com/catalogsearch/result/?q=IS-LCDTV32+
As you can so many parts available, it may mean a lot of failed TV for this brand.
Posted on Dec 10, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Red power light flashes and set wont come on
Hi
Turn off the tv for five minutes and then turn on..
Can u tell me model no and company name so that i can help u clearly
thank you
Oct 12, 2008 | Hitachi 46F510 46" Projection HDTV
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
Tv doesn't connect though coaxial hook up
Most of these TVs show a blank screen unless they are receiving a sinal?
Jan 28, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
When turning on the TV, the on light is on, however it's not connecting to our cable system and the screen sits blank. We had the cable company come out to check the box and he informed us the box is...
The tv Tuner signal board it is dying,that why tv requiring to turn on and off a few times to get the tv incomming broadcasting signal work,to get a picture.The tv Tuner signal board, that the board that take in the incomming broadcasting signal cable and other external devices plugin to it like a DVD players and games systems.Can u take things aparts and putting it back togther again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for to do the replacement.
Jan 27, 2011 | LG 47LG50 47 in. LCD HDTV
I turn on the Tv the sound comes on & the picture is blank Cablevision was here & said it's a problem in the set
He is probably not an expert (just kidding, of course he's not..) First, try connecting the Cablevision Box to another TV (if you don't have another HD TV, use the yellow/white/red Composite connection.) If there is still no picture, the box is no good. If there is, then try a different output from the Box or other inputs on the TV. Are you using HDMI (HD connection) out of your Box? Is the TV 720p or 1080p? Set the Box up (from the menu) according to the specs of your TV. Hope I helped.
Jan 11, 2011 | Samsung Televison & Video
Screen is blank but can hear all the channels. cable guide shows up but no picture. What do you think the problem is
The video circuit section of your LCD needs service and this will require board level troubleshooting and by a qualified service tech. There is a light tube or floresent tube that excites the liquid crystals to give visual to the screen and it may have blown and needs replacement.
Feb 04, 2010 | Insignia IS-LCDTV32 32 in. Television
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Insignia IS-LCDTV32 32 in. Television Logo
183 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
