Question about 2wire PC Port Phoneline HomePNA 10Mbps USB Adapter
Belkin Dongle Hi Ihave a working belkin router which connects my computer to the internet, my sons computer in his bedroom is saying excellent connection through belkin usb dongle. but there is no connection to the internet from his computer .Can you please help. Thanks
  • deaeme Jan 19, 2008
    Scholar:
  • 141 Answers
You have to make sure first that the working pc is getting its internet connection from the BELKIN and not from the modem. To check that, right click the computer icon at the butoom right of your screen, click detail. ip address that is ok is in this form 192.168.xx.xx. If you are getting like 74.xx.xx.xx, that means that you are getting connection from the modem. THE MODEM ONLY GIVES ONE CONNECTION, MEANING THE ROUTER IS NOT FUNCTIONING CORRECTLY. After doing this you can give a follow up question.
Posted on Mar 12, 2008
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin wireless G router and MicroNet Realtek RTL8187B USB
I got the answers (for free) from Belkin's excellent technical support.
Many thanks.
Jun 18, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin 802.11a/b/g usb adapter
It sounds like the plug on the USB wireless dongle is bad or the usb ports in your computer are having problems. My Toshiba notebook does the same thing with the two usb ports near the front of the computer but works fine from the two on the back. When you have a flash drive plugged into the USB do you frequently get the new hardware found message as if you had unplugged and replugged the drive? If you have a powered external USB hub try plugging that in first then when that is stable plugging the USB wireless dongle into the hub rather than the computer. If it is stable then the problem is on the power pin in the USB port of your computer. Good Luck
May 10, 2009 | Belkin Pre-N 802.11g/b Wireless Adapter
No internet through belkin g router
hi we had the same it is belkins fault i had to buy a wireless router from vigin .i have mine for about 7 months now and had no problems at all hope you get it sorted
Nov 30, 2008 | Belkin (F5D7230-4) Router (587009)
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
Connecting belkin router
Hi!
How far are you away from the router to the bedroom?
What do you mean by "bedroom system"? Is it a wireless computer?
Apr 13, 2008 | Belkin (F5D5231-4) Router
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless Internet Connection
Are the wireless router connected to a network?
Oct 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
2wire PC Port Phoneline HomePNA 10Mbps USB Adapter Logo
188 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
