Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Green timer light keeps blinking and wont stop tried reset button
  • Mitsubishi Master
  • 8,617 Answers
The DM capacitors have failed and need replacement. You can get the V26 DM repair kit at www.tvrepairworld.com the kit contains the capacitors and the CD with detailed repair instructions.
Posted on Dec 10, 2009
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
195 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
