Question about Nintendo Wii Console
No power checked all connections still no power
  • 143 Answers
If you have a friend with a wii I would check his power adapter against his, as it could be a faulty adapter. Another thing I have seen is the WiFi chip becoming unplugged inside of the unit which will sometimes not allow the unit to power on. This will require that you disassemble the unit. It is located under the cd drive in the front.
Posted on Dec 10, 2009
LFX25974ST. Why does it have no power?
check for broken thermostat connection and compressor overload loose connection. check power cord plug. check continuity of power cord. with all of these found good, check connection to the control board. if good but still no power change the control board. thanks .
Aug 17, 2015 | LG Refrigerators
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
Last green light flashes
1 Flash The batteries need charging. Check the battery connections. If the battery There is a bad connection to the batteries. connections are good, then try charging the batteries. 2 Flashes There is a bad connection on the left motor. Check the left motor connections and wiring harnesses. 3 Flashes The left motor has a short to a battery Contact your authorized Pride Provider. connection. 4 Flashes There is a bad connection on the right Check the right motor connections and wiring motor. harnesses. 5 Flashes The right motor has a short to a battery Contact your authorized Pride Provider. connection. Rippling LEDs The charge inhibit has been activated. Make sure that the battery charger is not connected to the power base. 7 Flashes There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. 8 Flashes There is a control system fault. Check power module and joystick module connections and wiring. 9 Flashes The park brakes have a bad connection. Check the left and right motor connections and wiring. Check to make sure that the power chair is not in freewheel mode. 10 Flashes An excessive voltage has been applied to Check the battery connections. the control system.
or go here and find yours,if you would of given the info we need,i would of diagnosed it for you,but,you didnt Pride Mobility Products Corp Basic Troubleshooting Instructions
Apr 20, 2015 | Health & Beauty
I have a IBM Intellistation Z Pro 6221 and it just shut down and has no power at all. I have replaced the power supply and still it will not start. Any ideas as to what could be my problem?
Hello..Flow instruction:-
1> Check you power connector it is proper connect or not.
2> if you are change SMPS power supply. check you power cable connect in mother board.
3> if not coming power then change you power supply. because this power supply not supported.
4> And finally check all power connection point. if any problem then contact best technician.
Thanks..
Feb 06, 2013 | IBM IntelliStation Z Pro 6221 PC Desktop
NO POWER OUTPUT ,THE LED LIGHT IS OFF
Check the line cord to see if it can carry power. Check the connection from the line cord to the power supply. It may be that the soldered connection is broken there and needs re-soldering. Check to see if it has any external or internal fuses that need replacing.
Sep 21, 2012 | Dell PWR SPLY,250W,PFC,HP,HIPRO Power...
No power from battery
See if you fuse box is getting power
Jan 11, 2012 | 1992 Ford F350
I have a bv7320 head unit i am trying to install into my ford ranger. i have all of the wires matched up and im not getting any power to the unit. i have a amp powering all my speakers and a seperate one...
Since you did not mention the year of the vehicle, I cannot be sure of the power/ground connection. However, if you are sure of the connections, let us proceed. Check the constant 12 volt for power. Check the accessory power connection for 12 volts when the key is on. Check the ground connection for a good chassis ground. If you do not have power at these connections, check your fuses at the vehicle fuse box and at the stereo head unit itself (if one exists). If all power and ground connection are good and all fuses are good and, your unit still does not power on, check and make sure that the pins in the stereo harness are properly seated.
If all of these things check out as good then the issue is with the head unit.
May 27, 2011 | BOSS AUDIO SYSTEMS BV7320 Car Video Player
Rear power windows wont work
First check the fuses for power with ignition on and a test light...if you dont have a test light locate power window fuse section and remove fuse carefully...some are hard to remove so you will need a plastic fuse puller or use small needle nose plyers...CAREFULLY..also check owners manual for relay.If they are not burnt you will have to check power at switch on the door panel...keep ignition on or have an assistant so you will not kill the battery by just leaving it on and possibly forgetting...You will have to remove door panel armrest assembly..some will become loose at connection and cause problem make sure it is connected good...you will have to have a test light to check power at connection...If power is at the switch check power from switch to window motor connection... check here for loose connection also...If power is good here and all connections are tight and clean the window motor has failed..
This is normal to go bad...but not both at the same time....check for a relay when checking for fuse
If you find a relay mail me back and I will instruct you how to check it...you will need a multimeter But if you dont have a multimeter it is best to take the old one with you to a parts store and get one like it....It will save you time and they are cheap.
I will be standing by............................hope this helps..............................
Mar 01, 2011 | 1995 Buick LeSabre
No power
Check for power supply power. Remove it from the motherboard and short or connect the green plus the black wire beside it. if the power supply's fan turns, then there's a problem with the motherboard.
Check for loose connection between the power supply and the system board. Apply WD-40 or contact cleaner on the contacts (mainly, this is a 24pin array connection) then unplug replug it to the motherboard.
Might as well check also for the power button's connection. Temporarily connect the reset switch to that of the power switch to check if the switch is the defect. Connect everything and switch it on.
Replug the memory modules including the processor but make sure you have a thermal compound handy to replace the gray/white paste-like matter between the heatsink and the actual processor.
Please do notify me if you need clarification, i'd be willing to provide a followup.
Hope this helps,
levibit
Dec 14, 2010 | ASUS P5KPL-AM SE Motherboard
No power - check all connections
If there's no power at all on the unit , try first connecting it a different power source and if still the same problem try using a different cord this can be a problem with the power cord....
Dec 13, 2009 | Dell 922 All-In-One InkJet Printer
Nintendo Wii Console Logo
88 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
