Question about Dell E171FP 17" Flat Panel LCD Monitor
Color set at lowest setting. Cannot adjust to a higher setting
    Guru:
  • 1,481 Answers
Resinstall diaplay drivers from the CD that cam with your machine...
Posted on Dec 10, 2009
How do I fix my color for the tv via the menu board there is no default button.
You usually can't go wrong by starting with all the settings set to a mid range, then adjust from there. From your video it seems as if it has been adjusted already very few TV's are set to the lowest settings. There are also "presets" that can be chosen I.e. " warm" or " cool" settings that maybe to your taste. (those choices will preset everything, I like the " warm" setting for my tastes.)
Jan 21, 2013 | Televison & Video
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
How set eq 6200
If you have an audio analyzer, you can make the adjustments so reponse is flat across the audio spectrum. Or you can set them so the audio you hear is closest to what you consider a true sound.
You use it to compensate for acoustic defects in the listening space. full auditoriums are going to absorb the high frequencies of the amplified material- so you would set the higher frequencies in a manner that produces the correct sound for something like a piano on stage, the lowest keys get muddied by an audience, as well as the high notes- so they get adjusted higher than mid values. Human hearing peaks between 400 Hz and 1200Hz, so those could be brought slightly below the zero detent- or attenuated.
The short of it is you make the adjustments so the music sounds good and no single instrument overpowers the others unless they are doing a solo.
Mar 27, 2012 | Behringer EUROPOWER EP2500 Amplifier
What is 1X, 2X,4X,8, 16X WRITE SPEED
HI. These settings are indications of the rate of speed that the actual CD-ROM disk will spin at. The rotation speed can be adjusted to the lowest, which is 1X, and the highest, which can be up to 54X; Depending on your brand of CD_ROM drive. Adjusting the settings to a 16X or higher rate, will decrease the burn time.
  • NOTE_ A high spin rate speed will decrease burn time, but it will also increase the chance of a writing error, as well.
Aug 19, 2010 | Computers & Internet
What is the lowest setting on the temp on a Hotpoint Ctf18ga
Hello Dustin,
Typically the lower the Letter or Number is the warmer setting for the freezer or fridge section. If you want to make them colder, move the control setting ONE (1) increment at a time, in any 24 hour time period (up or down) and allow the fridge to adjust before making another change in the settings.
Again, A is warmer than B, and 1 is warmer than 2, and so on. So going to a higher letter or number, will make the unit colder.
Just remember it will take at least 24 hours for your unit to adjust and compensate for the changes, so only make them gradually, so you can tell if you've reached the desired cooling settings for both the fridge and the freezer. Typically, most manufacturers recommend that the starting position be in the middle of the dial and that you adjust them up or down from there.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Refrigerators
What type of gas should i use in my 1997 dodge ram. 3.9L engine
Your owners manual should specify this, as well as the under hood sticker, and sometimes the gas fill has a label.
You want to use the LOWEST that you can, as lower octane is more explosive than higher... (reverse of what you thought...). Higher octane RESISTS detonation, by lower volitility.
Vehicles now days automatically adjust timing, EGR and other settings when detonation is detected, so probably you would notice nothing across several octane levels.
Lowest octane will deliver the best performance and mileage...
Oct 10, 2009 | 1997 Dodge Ram 1500 Club Cab
Cannot adjust color
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
Jul 15, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
LG lcd computer monitor
try to connect your old monitor and adjust your screen properties down to 800x600 with medium color setting..or go to xp safe mode, adjust screen properties to the lowest setting, xp has not yet installed the monitor driver of your lg lcd monitor.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Zenith cov. problums
THose are G2 settings they have to be adjusted to certain voltages. You can ball park the adjustment by setting conrast, ad brightness levels to 50 percent. Shut color level to its lowest setting then adjust each screen control to achieve a good black and white picture not too bright. then turn your color and other controls back up. This should get it ball parked for you. Anything further and you would need the service manual. If you'd like a service manul let me know I have a link that has them at a cheap price and provides free support with them.
Jan 14, 2008 | Zenith IQC50H95W 50" Rear Projection...
Dell E171FP 17" Flat Panel LCD Monitor Logo
52 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
