Question about Cell Phones
The blue tooth feature only works for outgoing
The blue tooth feature on my Samsung cell phone only works for outgoing calls.
Outgoing calls Problem
Transfer SIM to another working device to check if outgoing calls will work. If problem still persists, please contact us via hotline or visit the nearest Smart Store. If you cannot make outgoing calls while roaming abroad, click here by Camera Mobiles Camera Mobiles Tablets
Oct 20, 2017 | Samsung Galaxy Cell Phones
AVIC-D3 Blue Tooth Call Waiting
Do a full reset to factory default settings, that should fix the problem.
Sep 28, 2008 | Pioneer AVIC-D3 Car DVD Player
Samsung b7320 omniapro call barring password
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
Jul 11, 2011 | Samsung Omnia Pro B7320 Smartphone
I am not able to make outgoing calls from mobile rest every thing is working normally
chek the following
(a) is ur phone locked
(b) is the outgoing calls barred by service provider
(c) has the outgoing call barring been activated
Feb 18, 2011 | Samsung SGH-L700 Cell Phone
How to I turn off Bluetooth
Just go to blue tooth sub menu then turn off you blue tooth. If it does not work , your blue tooth is in problem and to fix at dealer.
Jan 30, 2011 | Samsung S3600 Cell Phone
My Bluetooth on my j700 wont turn on. help me to fix it
I'm sorry to tell you this, but the fact is that, most Samsung phones are having blue-tooth problems. Some times it might work and other times it might not work. Blue-tooth on most Samsung phones don't work at all and yet they claim to have blue-tooth.
I am saying this out of experience and you can ask other Samsung users confirm this.
I have come across a lot of Samsung phones with this problem, but the fault is from the maker (Samsung) of the phone.
So, you can adapt to the phone like that, or go for another product like Nokia that has an efficient blue-tooth,
Take care.
Sep 22, 2010 | Cell Phones
Blue tooth
well it may not be the phone it could be the BT Headsets you should tRY ANOTHER one.....also you can do a reflash of the firmware as well
Sep 01, 2008 | Samsung SCH-u740 Cellular Phone
Blue tooth
try another BT headset and you can also try reflashing the firmware on the phone.
Problem with blue tooth
Tak the phone to a mobile shop and ahve it diagnose the problem but from what you wrote....your phone's need reflashing to erase the corrupt files on the phone to make it read the memory card is there..and your BT is working from both incoming n outgoing
Aug 22, 2008 | Sony Ericsson W550i Cellular Phone
Hands free problem
lo m8 it sounds like a problrm with the ribbon that conneccts the 2 boards.try replacing it or you can send it to these guys to get it done. http://www.mobilephoneservicecentre.co.uk/
Jul 24, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
