Question about Panasonic Televison & Video
TV turns off when restarted no picture
TV turns off and when restarted somtime no picture if you wait it returns
    Problem Solver:
  • 18 Answers
OK WELL IF YOU HAVE A DLP REAR PROJECTION IT COULD BE TWO THINGS 1: THE LAMP THE ORIGINAL ONES ARE GOOD FOR 6000-8000 HOURS MAY EQUAL 2-5 YEARS IT COULD BE THAT ITS GIVING UP ALREADY AND IT GOING OUT OR 2: IT COULD BE A BALLAST ISSUE THIS BOARD IT THE POWER BOARD TO THE LAMP IF ITS NOT SENDING THE LAMP THE CORRECT AMOUNT OF VOLTAGE THIS COULD HAPPEN NOT A ABLE TO KEEP THE LAMP ON BUT MOST PROBABLY ITS GOING TO BE THE LAMP
IF ITS A LCD REAR PROJECTION THE PROBLEM COULD ALSO BE THE BALLAST BOARD OR IT COULD BE THE POWER SUPPLY IT MIGHT BE SENDING WRONG VOLTAGE TO THE BALLAST
HOPE THIS HELPS GOOD LUCK !!!!!!!!!
Posted on Dec 09, 2009
When u push the power button the tv tries to turn on, makes 3 switch noises and then the power turns off
this is somtimes a bad power supply or fuse if you have sound it likly and no picture usaly a fuse put this seems pretty much like a power supply issue this regulates power from the wall to each component of the tv like the picture and the souns amp
Dec 20, 2009 | RCA D52W136D 52 in. TV/DVD Combo
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
No picture
Try a hard restart, which simply means unplugging the power cord, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics, to a certain extent. ( Turning it off and on again by a switch will not work). If the picture does not return, then you might need the expertise of a TV repairman.
Jul 07, 2008 | Insignia 37" LCD Flat-Panel HDTV
No picture but I have sound
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If the picture does not return, then your TV has a more serious problem, that requires the attention of a repairman.
Jul 02, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
No picture but has sound
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Oct 30, 2007 | Sony KV-36XBR450 36" TV
Metz CRT TV G3478 color problem in PAL mode
I see from your profile that you have not specified your location which make it tricky to be sure which standard you should be using.
Oct 07, 2007 | Televison & Video
Picture failure
Do not have a clue without a model number and make. Are we to be fortune tellers here too?
Oct 04, 2007 | Televison & Video
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
