Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Big black mark over most of the screen with various colors all around
  • Sony Master
  • 8,457 Answers
Ur backlight video board is dead.Muust replaced to solved this problems.
Posted on Dec 09, 2009
I have a magnavox big screen tv that was giving to me. i do not have the manuals with it. when i turn it on. the color is in three demension I cannot get it adjusted where they colors are all together.
hi,
first of all check the tint setting on your TV picture menu.
if not get the correct color then, your telivision is a dlp TV that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for counting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
ok
Feb 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Television has double images like 3D, and bottom half of screen has a concaved image.
Please replace convergence ICs in tv, there are two big black ICs that has number STK392-110 mounted with big aluminum heat sink, replacement these ICs will solve your tv problem. Also check big resistor nearby these convergence ICs and replace if found burn mark or color faded.
On circuit board, IC location number is IC7001 and IC7002
Let me know if you have additional question.
Thanks.
Dec 25, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
Samsung HL-P5063W audio is fine, no picture. Initially made a loud buzzing sound, so we replaced the color wheel. No more buzzing sound, audio is fine, but screen is various shades of white. Left TV on for...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Nov 10, 2009 | Toshiba Satellite P105-S6064 Notebook
Black screen with colored vertical lines
YPU HAVE A BAD PANEL. THE COST OF REPAIR WILL PROBABLY EXCEED THE VALUE OF THE SET.
Mar 20, 2009 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Sony Screen keeps Blinking
If the red LED blinks 5 times you have a AKB error. It is caused by the CRTs trying to balance the color, and failing. Its an annoying problem that happens when the CRTs get old. If its just beginning you can balance or slightly turn up the screen voltage to the CRTs to remove the problem, if its in the end stages, the CRTs may need to be replaced. This is however, very expensive. If you are daring and safe around high voltage, pop off the speaker grille, open the front panel up and find the focus block. Don't poke around! those big red wires have 30,000 volts running through them! The focus block is a black square box with six knobs on it. Three are labeled screen, three labeled focus. You will see each row labeled R, G, B for red green and blue. The writing is tiny. Mark all three screen knobs with a colored marker so you know where they started. Then turn each one up slightly. If you have a picture, put it to a black screen or blank input. Turn each knob up just unit you see the color over drive and turn it back down to black. You want to set it just below retrace to maintain black level but drive the CRT fully. Setting this is hard but may fix an AKB issue.
Dec 02, 2008 | Sony KP-61S65 61" Rear Projection...
Color alinment
Replace your STKs big black ics 392-020 go to 040s if they are 110s,150s go to 180s.
Oct 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
BLACK SCREEN
you could be having some problems in the HT area. look for a burnt low value resister that is around the fly back transformer. the value of the resistor is marked by their color. so look and check the resisters that have gold on the third band of its color.
Nov 03, 2006 | JVC AV-36980 36" TV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
