Question about Bosch SHU3306UC Built-in Dishwasher
Bottom tray with float gets full of water and won't let water in until I soak it up with a towel. then it will allow water in and continue. Took float out and cleaned still have the problem. What causes the bottom tray to fill with water? Thank You!
  • 1 more comment
  • jbcmjones_11 Dec 09, 2009
    Thanks for your reply,
    You mentioned aqua stop, not sure what that is. I understand how the float works, I guess I really need to know why I'm getting so much water in the white plastic tray that it activated the float switch?
  • jbcmjones_11 Dec 10, 2009
    Thank You. Your advice is dead on. After watching it run for a cycle or two I noticed a leak toward the water inlet system as it was filling. I will Pull it out today to see if it's just a fitting or a component leaking. I'm not sure how deep to get into it it is at least 6 years old. If I have further questions I will certainly ask your advice.
  • jbcmjones_11 Dec 11, 2009
    Thanks to everyone who helped. Following the troubleshooting advice I found the Problem. There was a small leak between the water supply assembly and the water level switch housing. Took them apart, cleaned them then just put a small bead of sealant on them when I put them back in. No More Leak works great again. The machine was simply doing what it was designed to do, buy not letting more water in because of the leak.
    President:
  • 704 Answers
Hello JbcmJones, It would appear that the discharge pump isn't allowing the water to properly drain. Sometimes it happens when a glass breaks and parts of the broken glass get down into the sump area and obstruct the drain area. In order to determine what the issue is, let's go through some steps to get at the problem.
First, remove the bottom rack and the spray arm. Now look for the the sump screen and remove it, as any blockage could have gotten past it and into the lower pump assembly. You can soak up any excess water to make this easier or use a wet/dry vac to do it too, which sometimes makes it easier to get out most of those obstructions.
Now very carefully check for any items (broken glass, plastic caps, pieces, etc.) that may have gotten into the sump and could be causing the dishwasher not to properly pump out during the drain cycle.
Once, you've done that, also check your "air-gap" (back flow device), if so equipped and installed on your drain line. These are typically installed at the sink top and are round metal caps with a filter screen inside them. If you have one of these, remove the cap by pulling and twisting it up and off. Remove the screen filter and clean it out and replace it.
Lastly, check the discharge (drain) line where it connects to your sink drain, either above the P-trap, or at the disposal, if you have one. You'll have to remove the hose clamp and check for any possible obstruction in there. While you've got it off, you can blow into the line to see if you've got a clear line all the way back to the dishwasher. If you hear air, then the line is clear. That should take care of the drain line issues.
One last remotely possible issue, might be that the microswitch is defective. It might be working intermittently and needs to be replaced, but not so sure that is the problem. Based on your observations and comments on the dishwasher working, once you have the excess water removed, I don't think that's the problem.
You should be able to hear the switch click when you lift and lower the float. Other than that, you would have to have a multimeter to verify it's working, but again, I don't really think that's the problem, since you get water flowing into unit after getting rid of the standing water.
Here's a line drawing that you might find helpful as you look at the sump area inside the dishwasher.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SHU3306UC-06&productCategoryId=0130000&brandId=1794&brandDescription=BOSCH&modelName=DISHWASHER&diagramPageId=00005&componentDescription=COMPONENT%20ASSY&documentId=50020714&blt=06
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
  • Bosch Master
  • 2,605 Answers
Hi, Having seen many, many of the issue you are dealing with I can direct you to check several possible causes. 1) Improper install with no "hi-loop" in the drain line. This allow's water to flow back into the machine when not present or previously there but the "hi-loop" has fallen down. 2) Drain line connected to a garberator/food disposer without any form of check valve or loop as I mentioned in point # 1. 3) Faulty inlet water valve. Bosch D/W's have a history of defective water valves which can potentially allow water to enter the unit even when not energized. 4) The outlet pump is faulty and not draining the machine sufficiently and therefore creating a overfill scenario somewhere during a normal wash cycle. 5) The drain hose could be kinked or obstructed somewhere between the pump and your household plumbing. 6) A leak has developed with one of the component's under the tub, i.e. circulation motor & pump face seal being the most common. These are actual problem's I've serviced on many occasion's. It can be any one or a combination of several, though not likely. Hope that provides you with the help you came to fixya to find. Let me know if I can assist you further. Good luck. macmarkus :)
    Brigadier General:
  • 3,917 Answers
Hi
Here is the troubleshooting that needs to be done. Beneath the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift and shut off the water intake valve. So long as that valve is closed, your machine wills not run. You might want to purchase a aqua stop.
Thanks for contacting fixya.com
Posted on Dec 09, 2009
My bunn coffeemaker NHS-B trip the GFI. Where do I find the code date on my brewer?
The NHS-B has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
P.S. If you did splash too much water then wipe up as much as you can. Leave it out on a towel or paper towels to allow the excess moisture to evaporate. If you dump all the water out of the brewer (and tank) then you will need to pre-fill it with a pot of water PRIOR to plugging in the brewer. Follow the set up instructions in the manual. Let it heat up and try again. If it's still leaking then there is a hole in the tank. Call for service.
Dec 29, 2017 | Bunn Coffee Makers & Espresso Machines
Wil165x. Full. How can I empty it?
Remove or open the vent at the bottom of the machine
Get a towel and a large baking tray or something similar
Place the towel underneath the vent and the tray to catch the water
Turn the filter slowly until u see water coming out, when the water slows down pull the filter out.
Clean out whatever is in there and replace the filter
Oct 02, 2015 | Indesit Washing Machines
Cme256 scotsman
Is it dumping water or is it pouring water back into the ice bin? if it is pouring water back into ice bin than check your water float to make sure it is not calling for water also make sure the water valve is not letting water seep buy you can cut power to machine and if you here water still entering sump tray then replace water valve. if not then turn machine back on check and see it the water full light is on if so and water is still entering sump tray then replace float switch. If water full light is not on and the sump tray is full of water than remove the water sensor and clean or replace it.
Jul 10, 2013 | Kitchen Appliances - Others
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
What does error code 2 means on proline washing machine
With mine when i had the error 2 code, it was money in the filter.
Switch machine off
I had to get a baking tray and a towel, i pu tthe baking tray under the filter corner, then slowly unscrew the filter (bottom right front of machine) then let water slowy trickle into baking tray and then empty, and repeat until water stops took about 20 mins. Of course you could do it quicker if you want to flood your kitchen. :)
Then emptied the filter, then ran spin only until end. worked fine after this.
Apr 11, 2011 | Washing Machines
Fridge drip tray removal
remove toe kick on bottom of fridge, should be some screws on both sides. tray slides out, maybe not all the way dont force, there is a float mechanism that will stop it from coming out all the way, use some paper towels or rags to soak up the stagnant water, this pan should have a heater hooked up to it to evaporate the water, the installer should have hooked this up on installation, they dont hook it up at the factory to get a better EER out the factory door, just trace back to the pan and hook up any unplugged wires going to it, good luck
Oct 31, 2009 | Miele KF7642S Bottom Freezer Refrigerator
Fault code f70, drain pump keeps running, nothing else works
Yes. F70 is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
May 29, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Diswasher Pump won't stop running
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills, OK, then this ISN'T a solution to your problem.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
May 04, 2009 | Bosch Dishwashers
Water trickling in back of refrigerator, inside, up on top back between the light bulbs. It ends up trickling in th eback and getting stuff on shelves wet. We just pulled it out and took off the bottom...
You have a clogged drainline. You'll need to remove the ice maker and rear wall of freezr. Take hot water and continue pooring into the drain located dead center until it starts draining. Have towels handy...
Mar 14, 2009 | Refrigerators
Error mesage E4
E4 commonly means an overflow detected in the bottom over flow tray - try removing the kick board from the front of the machine - you should see 2 plastic black panels about 4 inches wide each, using a flat edged screwdriver pop the panels off and you will see the mechanics of the machine - the base is classed as the over flow tray - when water fills this tray a polystyrene float is pushed up and an E4 error code is detected - tilt the dishwasher back and allow the machine to dry out before trying it again - this should work unless the water seal around the filter basket is broken - in this case an engineer should be called to replace this part. Hope this Helps.
Thanks
Donna
Nov 06, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Bosch SHU3306UC Built-in Dishwasher Logo
137 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
